Need Finally an upgrade...
Solved by .Apex.,
@WhiteAirLock
https://pcpartpicker.com/list/6mRzhy
closest i could get it to 180 euro (205 dollars), you can swap out the case if you want, but you can't go lower than this unless you buy used stuff.
also make sure you get 2 x 4gb ram sticks, not 1 x 8gb, dual channel is important.
popularlion ·
Posted in Troubleshooting1 -
CallMe_David ·
FancyPants101 ·
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming1 -
6
