Hi, I want to buy a new TV, but I'm not sure which one should I choose.
So I need These specs for sure:
4k screen
lan port (possibly Gigabit for 4k youtube videos)
Enough cpu power to display 4k -> Well this is my main problem. I have a NAS on my network which has an NFS share on it. When I tried TCL 6046 TV with this configuration and well.... It just can NOT play 4k videos from NFS share.
I only have 700-710 U.S. dollars for it. (I'm from another country with other currency. So it's a converted value.)
Please help me, I'm getting confused from the manufacturer's promises.
Thank you so much.
Sorry if my English is bad.
https://linustechtips.com/topic/959239-need-help-buying-tv/
38 minutes ago, Skeleton022 said:
TCL 4K+soundbar is the easy/only choice
https://linustechtips.com/topic/959239-need-help-buying-tv/#findComment-11636582
On 8/13/2018 at 4:35 AM, Skeleton022 said:
I’m from Hungary.
My only problem with the TCL is when I played a 4k movie on it, the film came out on both sides of TV.. And I downloaded Aida from play store, and it says: Display 1920*1080.... I bought that tv as 4k...
(TCL 6046)
Is that like connecting your phone or something to the TV? need HDMI 2.0 for proper 4k 60hz
Not sure what you mean by both sides of the TV, was the display split in half? where were you able to test it?
https://linustechtips.com/topic/959239-need-help-buying-tv/#findComment-11645879
