Hey,
I was looking into adding a second GPU to my computer. I current have a XFX xxx 580 8GB. I was curious if i would be bottle necking my CPU and does the brand of Crossfire bridge matter?
Computer Specs
CASE: NZXT Phantom Green
CPU: AMD RYZEN 1700 (OC)
GPU: Radeon RX 580 8GB
RAM: G.Skill 32GB DDR4 3200 x4
MOBO:GIGABYTE AORUS GA-AX370-Gaming K5
PSU: EVGA 850 B3
This is what i would be getting, its the exact same as my current
https://www.amazon.com/gp/product/B06Y66K3XD/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
https://linustechtips.com/topic/958659-amd-580-cross-fire/
Not a bottleneck, just a weird configuration. Sell your current 580 and buy a 1080
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11631997
7 minutes ago, Lindows said:
Hey,
Computer Specs
PSU: EVGA 850 B3
you also dont need a crossfire bridge.  AMD did away with that nonsense years ago.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11632002
2 minutes ago, emosun said:
only if your cpu is being maxed out , have you checked any of your usages?
CPU usage is always pretty low, even while running PUBG
So, I would just install both of them and they should just work
5 minutes ago, Derrk said:
1080 would give you better fps than crossfire 580s
Yeah, I kind of figured it would but RX 580's dont sell for much in my area.
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11632030
should just work, youll have to enable it in the driver, obviously.. but yea.
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11632039
 mmmm thats seems fake , are you with dual monitors? or minimizing game to look that? Cpu usage needs to be measured at the same time you are playing, it's not like gpu
If I were you I would sell that 580 for 200$ and buy a 1070ti/1080
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11632057
It Varies between 14-30, on ultra with 3 monitors running 1440p (while running)
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11632150
Crazyyyy dont play on ultra , never say fps on ultra thats high demanding 0 fps optimized
I had a rx480 and now a 1070 (had a rx 480 8gb + 2500k now a 1070+4790k oced) and I can run pubg at 1440p 80-120fps  on reddit they posted the best settings for pubg, and with that card i wont ultra anything
Better if you can buy a 1070ti than any 580 como , the ideal case that amd said is with 100% xfire compatibility it would have same performance as one 1080(1070ti) so I think even a 1070 will give you better gaming experience , you have a great cpu just need more power than a 580 (its like a 1060)
Best settings from reddit (I check everyday /r/pubbattlegrounds)
And for a 580 dont do more than this. (if you have a better gpu just up the screen scale)
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11632204
I had a rx480 and now a 1070 (had a 480 + 2500k now a 1070+4790k oced) and I can run pubg at 1440p 80-120fps  on reddit they posted the best settings for pubg, and with that card i wont ultra anything
Well, this is what i was mainly looking at, a crossfired 580 is comparable to the 1080 (roughly 5 frames different). And it looks like the 1080 outperforms the 1070 ti if this video is accurate
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11632239
Well I would bet my money that a 1070ti can bet any 580 sli rig, the same time that you need (or less) to tune a 580 sli you can spend in tuning your 1070ti  to be a 1080 full
I told you this because with my 480 was thinking the same but I just learn this year that the best hardware are not on numbers in a game like pubg fps , are in the full game experience , and that a sli would never do (you will have drawbacks on other games , or a lot of things if its for gaming for me its a no-no) a 1070ti/1080 will give you full 144hz/fps in any game that you are playing now, 0 tuning , 0 power issues , just plug and play...
If it were vega I would say buy a vega, Im not tied to brands , I bought a 480 when was at 260$ and sold it at 330$ more than 6 months later.(I think I have luck with computer deals , or just I research a lot , but bought my monitor (dell s2417dg) at 430 euros , now its at 470 xD , its like now the dell s2716dg its at 450$ on amazon.us I dont know why people are not buying that massively , 450$ for a 700$ msrp monitor)
https://linustechtips.com/topic/958659-amd-580-cross-fire/#findComment-11632247
