cpu overheating
Go to solution Solved by jiyeon,
23 minutes ago, vilobike said:
idle its usually 41 c
That's a little hot, ideally idle temps should be averaging 30-35.
This could be a lot of things:
• Too high voltage on the CPU
• Incorrect cooler mounting
• Lack/Excess thermal compound application
You could also set the fan curve of your cooler to be more aggressive in lower temps, it's a nice way to get some more performance out of your cooler and also keep your CPU at optimal temperatures.
im a little bit at a loss 2 days ago i finally built my first propper gaming pc whit be quiet gear but my cpu seems to be running to hot when i game 81 celcius however when i use intels stress test it only goes up to 75 70 average idle its usually 41 c average is this normal should i do something to get my temps lower?
its a intel i7 8700k my cooler is a dark rock pro 4
any advice? sorry for my bad english
https://linustechtips.com/topic/958518-cpu-overheating/
Do you have other case fans installed? Which GPU do you have (and blower or open air cooler)? Ambient temp?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/958518-cpu-overheating/#findComment-11630773
mmm I suggest to instal again the cpu cooler, you put enough termal paste? I have a friend that has mounted a nhd15 and in games with a 8700k/1080 max 65-66º
Maybe its mount maybe you have factory oc'ed your cpu, (maybe you have like 1,35v constantly on your cpu like oc'ed) , those 2 things are the most common, disable all oc on bios and look for any silent fan config, but if I where you first ensure that you mounted your cpu well... (Even the pro's check that if they had the same problem as you)
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/958518-cpu-overheating/#findComment-11630792
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/958518-cpu-overheating/#findComment-11630814
i went into my bios and turned my cpu coolers fan curve up way higher and whit the stress test seems to be 5 celcius better a fair bit louder now but worth it my last pc got ruined becuase of constant overheating if it gets any worse ill reinstall the cooler thanks for the help
https://linustechtips.com/topic/958518-cpu-overheating/#findComment-11630847
