31 minutes ago, Tyler Moore said:
Depends under which encoder, nVidia does it quite well and the hit is very minimal. Could maybe expect 1080p@60 but certainly not maxed out on some games. :)
22 minutes ago, Dan Castellaneta said:
Depending on how you set it all up 1080p60 or even 1440p at 30fps should be doable just fine.
10 minutes ago, WereCat said:
Quite good actually if you will use 7000bitrate with fast or medium preset at 720p60 or 1080p30.
You may even pull off 1080p60 with that CPU.
I have a 175mbps download and a 16mbps upload. I run most my games on the low preset because I play competitive games and sometimes these settings can alter my performance as a player. I'm just trying to find the right settings for my stream to eventually reach 1080p60fps. I will be upgrading my GPU but not for a couple of months
https://linustechtips.com/topic/958325-stream-quality/#findComment-11629280
1080p60 is pretty much out of question because of weak upload. You need over 20mbps upload for good quality 1080p60. Stick with 720p60. 1080p can limit ingame graphic options as your GPU is only midrange still.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/958325-stream-quality/#findComment-11630164
