3 minutes ago, VegetableStu said:
are you asking about how much power does it actually draw? ._. because that actually depends on how much power your PC is consuming.
the PSU will not draw all 1000W (or 83.3A) from the wall when your PC only eats (say) 420W (or 35A). when you reverse the numbers that's when your PSU stops itself to prevent itself from burning out
oh i understand thanks
Don't think I get what you're asking...
The PSU can be plugged into a 120V AC or a 240V AC, doesn't matter.
If you didn't know that, are you sure you NEED a kilowatt power supply?  What are you powering with it in total?  If you're not going with a rig that would rival most crypto-mining GPU rigs, probably not.
  • 2 weeks later...
overclocking
