Tips for cable managements please.
Go to solution Solved by TVwazhere,
8 hours ago, Rallenhayestime said:
cable management is impossible on any matx case...
False!
8 hours ago, Altruist said:
I don't know what else to say apart from the fact i have fractal design define mini c, and the bequiet pure power 10 cm 400w
You can use my Purple Build in my signature as a guide, since I use that exact case ;)
False!
3 hours ago, Altruist said:
The define mini c?
I have that exact case ;D
The Fractal Design Cases are easy to cable manage in. I've now worked in two of them (both the same case more or less, The Define C and Define Mini C) and they're just great to work in.
