Hello, planning my first PC build at the moment. Looking to get this motherboard: https://www.gigabyte.com/Motherboard/X470-AORUS-GAMING-7-WIFI-rev-10#kf . Noticed it has both a 4 pin and an 8 pin ecs connector on it. Are both of these required to be plugged in and if so is there a specific keyword to look for when searching for a Psu to ensure it has a second port for the second cable
https://linustechtips.com/topic/956464-84-pin-eps-connector-required/
The 8-pin EPS 12V is required. The 4-pin ATX 12V connector is optional, and even for a Ryzen 7 2700X overclocked to 4.2 GHz at, let's say 1.425V, doesn't draw enough current for the two connectors to be needed. The 8-pin EPS 12V would handle that CPU within those parameters just fine, and so the extra 4-pin ATX 12V connector for the CPU is unnecessary.
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
nah, dont need that extra 4pin. A single 8pin EPS connector can output 480W of power, a lot higher than what a 2700x under ambient cooling will draw (~250w, taking VRM efficiency into account) while overclocking without pouring dangerous voltages into it.
Of course, dont buy PSUs that are dodgy just because 'it has an 8pin EPS'.
Desktop benching:
