Will there be any lost features (besides overclocking) on a B360 chipset compared to Z370?
I'll be using a B360 board with my 8086k until I can afford a higher end Z370 board and I want to know what features I will gain (again, other than overclocking).
Also, does it impact CPU performance at all?
-Parts-
Core i7 8086k 4.0GHz (4.6GHz OC) - ASUS z390 ROG Maximus XI code - Corsair H115i - 16GB (2 x 8GB) G.SKILL Trident Z RGB 3600MHz - Windforce GTX 1050Ti - Corsair HX750i - Corsair Obsidian 500D RGB SE
-Upgrades when I get the money-
Undecided on the GPU - ASUS ROG PG278QR 1440p 144Hz (165Hz OC)
https://linustechtips.com/topic/956378-features-difference-between-b360-and-z370/
Motherboard usually doesn't impact CPU performance.
B360 also has no multi GPU support, less drive support(you won't be able to connect as many drives) and is lower quality overall(but not a bad budget option).
2 minutes ago, Shyam Ganapathy said:
overclocking
*this was a joke dont get triggered*
The pinnacle of human performance pictured in one comment
-Parts-
It does have AMD crossfire apparently
-Parts-
My bad.
