Hello Forums,
I'm about to purchase my new system, and I'm wanting to know about different fans.
I''v chosen Corsair SP'S and AF fans in 120mm and 140mm
As shown in this diagram:
Upon reading and researching, the AF140's only come in a quite variant unlike the 120's which have a performance and quite variant.
Reading comments and reviews on the quite version of the 120mm and the 140mm people are saying the quite version does not produce a lot of airflow compared to the performance which does not come in 140mm.
Since this case isn't so well optimized for air cooling which fans should I be buying?
What do you guys think, it would be nice if the fans were all the same. (Colored rings)
Configuration -
Top fans- H100I intake and having af120's on the other side of the radiator to push cool air down from the top. Fan on the right is also a AF120mm intake.
Rear- Exhaust (AF140)
Drive bays Intake x2 (1 120mm and 1 140mm)
Lower portion both intakes (2x 140mm)
This is also the list of parts that will be inside the build
https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=151930&action
Thanks guy!!
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/9559-optimal-fans-for-case/
Agree with Helltech. Corsair fans arent that good performance fans. i would only get these fans for aesthetics reasons. I always choose performance before looks, so i would go for Noctua fans.
Intel Core i7-3770K @ 4.9GHz |--| Gigabyte Z77X-UP7 |--| 16GB Crucial BalisitX Elite @ 1600MHz |--| Sapphire + Gigabyte HD 7990 in Quad CrossfireX @ 1,100MHz |--| Samsung 840 Series 250GB SSD |--|  2x Seagate Momentus XT 750 GB HDDs in Raid0 |--| CoolerMaster V1200 Platinum |--| Corsair Obsidian 750D
"There is no heaven or afterlife for broken-down computers; that is a fairy story for people afraid of the dark." - Stephen Hawking
https://linustechtips.com/topic/9559-optimal-fans-for-case/#findComment-104635
Triple-agreed on the Corsair fans. They really are crummy. Bitfenix Spectres are my go-to fans, because of their high air pressure in spite of being airflow optimised. It really helps when generating air flow through mesh (which is what? Every case ever?)
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/9559-optimal-fans-for-case/#findComment-104673
I was mainly going to purchase the Corsair fans for aesthetics.
@NihKiller I understand that those fans are one of the best, but I would never use them in my computer because of the color.
@That Norwegian Guy : Are these the fans you are talking about http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_598&products_id=20747
Bitfenix has two variants are PWM and a non PWM.
The PWM one is a lot louder than the non PWN. That shouldn't be a problem though, since I can use Corsair Link to control them.
https://linustechtips.com/topic/9559-optimal-fans-for-case/#findComment-104916
I say go for Cougar Vortex fans.
http://www.ncix.com/products/?sku=69269&vpn=CFV14HB&manufacture=Cougar&promoid=1449
They move a decent amount of air and are very quiet.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/9559-optimal-fans-for-case/#findComment-104950
The Bitfenix Spectre Pro fans are a good choice for fans.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/9559-optimal-fans-for-case/#findComment-104963
I'v decided to choose the Bitfenix fans over the Corsair ones. The Bitfenix fans seem to have great airflow specs.
Thanks everyone
If anyone else has any more fan suggests please comment.
https://linustechtips.com/topic/9559-optimal-fans-for-case/#findComment-105213
