Fan recommendation?
I want to buy an LED fan. IT has to have RED LEDs and fit in the back of a fractal r4 (140mm). I really need something that stands out inside of my case and this would go awesome with my black/red theme.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/95552-fan-recommendation/
Its the dolphin guys :) :3
Thats me hehe
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279202
the corsair red led ones.(not a big fan of led fans)
Noctua or GTFO.
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279204
Noctua or GTFO.
Why dont you like LED fans? Is there problems with them?
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279216
Noctua or GTFO.
Aren't those only 120mm -_-. I'd want to say get those sexy black Noctua server spec fans but they'll eat your wallet...how about trying Be Quiet just colour the logo red since its black.
Edit : Just realised...they do sell the Corsair LED fans in 14cm size.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279221
The lighting is kind disproportional to adding a good enough lit effect in some cases. You'll get some light off of them but not too much. I guess they look slightly overpowering.
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279236
I Think it would look cool if the fan was only lit up not letting of an immense glow.
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279252
You can get a 140mm
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279254
You can get a 140mm
I edited my post after searching on a retailer website. But they're slightly ugly I mean they're good but ugly...
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279282
LEDs im assuming are purely cosmetic? There arent that many 'great' LED fans. Just some cool ones
i havent seen many 'unique' 140mm LED fans. I would just use a 120mm.
theres the Lepa Choppers (go to around 2:40)
i use Enermax Vegas Trios but they now have a quad version (i heard a rumor theres a new version :) )
They work pretty well but lkike i said, theyre solely cosmetic
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279294
You call this ugly? http://www.corsair.com/us/cpu-cooling-kits/air-series-led-fans/air-series-af140-led-red-quiet-edition-high-airflow-140mm-fan.html
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279296
http://www.corsair.com/us/cpu-cooling-kits/air-series-led-fans/air-series-af140-led-red-quiet-edition-high-airflow-140mm-fan.html These look badass and linus said they are better than fans that come with cases in his Review.
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279310
its the only non ugly led fan id probably ever buy. my recommendation.
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279319
Probably better and quieter than the r4 fans anyway so ill buy that.
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279325
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279330
Yes...I do and I'm on Noctua side :)
Want me to go dolphin on your ass xD
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279338
Oh no....not the Dolphin on ma ass!!!!!!!!!!!!!!!!
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279345
I don't know any stores in Sweden...but..
Prolimatech 140mm red LED PRO-RV14LED. http://www.newegg.ca/Product/Product.aspx?Item=N82E16835242012
NZXT Airflow series 140mm red LED RF-FZ140-R1 http://products.ncix.com/detail/nzxt-fz-led-series-140mm-red-case-fan-1000-200-rpm-83-6-cfm-24-5-dba-3pin-and-4pin-72-80471.htm
@WoodenMarker, any other recommendations you can thing of? O.o
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279722
I'd recommend the Red LED Prolimatech Pros. I have the blue ones myself.
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1279748
Maybe the Coolermaster 120 MM Sickelflow red but there kinda loud so otherwise maybe the red LED version of the Corsair SP Series
  CPU:   Intel I5 3570K @ 4,6 GHZ   -- MOBO: Asrock Z77-Extreme4 -- GPU: EVGA GTX 770 2GB -- PSU:Corsair TX750M -- R AM: 16 GB 1333 MHz -- HDD: 2x 2TB -- 1x 120 GB HyperX SSD -- AUDIO: Creative Audigy 2 -- CASE: Fractal Design R4
-- Actually Like Windows 8 --
https://linustechtips.com/topic/95552-fan-recommendation/#findComment-1283380
