Posted August 1, 2018 This Is probably going to be my last post about this PC build. I think that I have found a reliable machine for light 3D modeling and occasional gaming(Fortnite and Kerbal Space Program). All I want to do now is reduce the price as much as possible without hurting performance too much. Most of the credit for this build goes to @Herman Mcpootis@forregacc02 and @Streetguru here are the current parts I am looking at PCPartPicker part list: https://pcpartpicker.com/list/J8wCFt Price breakdown by merchant: https://pcpartpicker.com/list/J8wCFt/by_merchant/ CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($149.99 @ Amazon) Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($49.99 @ Newegg) Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory ($80.98 @ Newegg) Storage: ADATA - XPG SX6000 256GB M.2-2280 Solid State Drive ($62.89 @ OutletPC) Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case ($29.99 @ Newegg) Power Supply: Corsair - Builder 500W 80+ Bronze Certified ATX Power Supply ($24.99 @ Newegg) Case Fan: Apevia - CF12S-BK 57.7 CFM 120mm Fan ($2.83 @ Newegg) Other: MSI GAMING GeForce GTX 1050 Ti 4GB GDDR5 DirectX 12 Graphics Card (GTX 1050 TI 4G OC) ($177.48 @ Amazon) Other: uphere 3-pack Long Life Computer Case Fan 120mm Cooling Case Fan for Computer Cases Cooling 15LED Red ($12.99 @ Amazon) Total: $592.13 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 09:52 EDT-0400 oh and how are you supposed to make a PC part picker list that you can click on? Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 I think I would get a cheaper quad core CPU and perhaps you could then squeeze in a 1060, but I am not sure about that Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597854 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Author @stefanDB thank you for the suggestion. The reason I don't want to cheap out on the CPU is because I plan on multi-tasking a lot. Do you think I will need that good of a processor for that? Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597878 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 get a CX450 instead of that, drop the case fans and maybe get a cheaper ssd and you should be able to fit in an rx 570/580 4gb/gtx 1060 3gb. CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597887 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Author @Herman Mcpootis I googled the CX450 is 450W power supply. according to the coolermaster calculator I need like 550w or 600w Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597903 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 6 minutes ago, Nstud said: according to the coolermaster calculator psu calculators usually show way more than you need. 30 minutes ago, Nstud said: Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($49.99 @ Newegg) Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory ($80.98 @ Newegg) You may have issues with that Ram on that board. It will work but you may not get the 3000 speed. If you still go ahead make sure you upgrade the bios to the latest version and select xmp profile in bios. Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597922 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Author @Beowulff83 thank you. Should I just get 2400mhz ram? Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597928 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 7 minutes ago, Nstud said: @Herman Mcpootis I googled the CX450 is 450W power supply. according to the coolermaster calculator I need like 550w or 600w the calculator's worthless, a 1050ti rig won't even go past 200w under load. CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597929 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 1 minute ago, Nstud said: @Beowulff83 thank you. Should I just get 2400mhz ram? 3000mhz is really nice with ryzen, but you probably need to update your BIOS Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597935 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 PCPartPicker part list / Price breakdown by merchant CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($149.99 @ Amazon) Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($49.99 @ Newegg) Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory ($80.98 @ Newegg) Storage: Team - L5 LITE 240GB 2.5" Solid State Drive ($44.99 @ Newegg) Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card ($199.99 @ Newegg) 580 if you can spend alittle extra.Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case ($29.99 @ Newegg) Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($23.98 @ Newegg) Case Fan: Apevia - CF12S-BK 57.7 CFM 120mm Fan ($2.83 @ Newegg) Total: $582.74Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2018-08-01 10:29 EDT-0400 CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597941 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Author @Herman Mcpootis Is this a good Idea? PCPartPicker part list: https://pcpartpicker.com/list/m9zH8Y Price breakdown by merchant: https://pcpartpicker.com/list/m9zH8Y/by_merchant/ CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($149.99 @ Amazon) Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($49.99 @ Newegg) Memory: GeIL - EVO POTENZA 8GB (2 x 4GB) DDR4-2400 Memory ($72.99 @ Newegg) Storage: Team - L5 LITE 240GB 2.5" Solid State Drive ($44.99 @ Newegg) Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card ($199.99 @ Newegg) Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case ($29.99 @ Newegg) Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($23.98 @ Newegg) Case Fan: Apevia - CF12S-BK 57.7 CFM 120mm Fan ($2.83 @ Newegg) Other: uphere 3-pack Long Life Computer Case Fan 120mm Cooling Case Fan for Computer Cases Cooling 15LED Red ($12.99 @ Amazon) Total: $587.74 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 10:36 EDT-0400 Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597958 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Author oh and also does anyone know about any cheap good wifi cards? Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597961 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 13 minutes ago, Herman Mcpootis said: the calculator's worthless, a 1050ti rig won't even go past 200w under load. PCPartPicker part list: https://pcpartpicker.com/list/FYFYQZ Price breakdown by merchant: https://pcpartpicker.com/list/FYFYQZ/by_merchant/ CPU: AMD - FX-9590 4.7GHz 8-Core OEM/Tray Processor ($89.99 @ Newegg) CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler ($149.99 @ Newegg) Motherboard: ASRock - 970A-G/3.1 ATX AM3+/AM3 Motherboard ($129.99 @ Amazon) Memory: Corsair - Vengeance 32GB (4 x 8GB) DDR3-1600 Memory ($649.99 @ Newegg Marketplace) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Video Card: MSI - GeForce GTX 1050 Ti 4GB GAMING X 4G Video Card ($204.98 @ Newegg Business) Case Fan: Thermaltake - Riing Plus 14 RGB TT Premium Edition (5 Fan Pack) 63.2 CFM 140mm Fans ($149.99 @ Amazon) Total: $3996.87 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 10:40 EDT-0400 PCPP says 561 watts CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 || LAPTOP: Dell XPS 15 7590 TABLET: iPad Pro PHONE: Galaxy S9 She/they Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597967 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 2 minutes ago, OrbitalBuzzsaw said: CPU: AMD - FX-9590 4.7GHz 8-Core OEM/Tray Processor ($89.99 @ Newegg) what a nice meme CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597976 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 6 minutes ago, Nstud said: @Herman Mcpootis Is this a good Idea? PCPartPicker part list: https://pcpartpicker.com/list/m9zH8Y Price breakdown by merchant: https://pcpartpicker.com/list/m9zH8Y/by_merchant/ CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($149.99 @ Amazon) Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($49.99 @ Newegg) Memory: GeIL - EVO POTENZA 8GB (2 x 4GB) DDR4-2400 Memory ($72.99 @ Newegg) Storage: Team - L5 LITE 240GB 2.5" Solid State Drive ($44.99 @ Newegg) Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card ($199.99 @ Newegg) Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case ($29.99 @ Newegg) Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($23.98 @ Newegg) Case Fan: Apevia - CF12S-BK 57.7 CFM 120mm Fan ($2.83 @ Newegg) Other: uphere 3-pack Long Life Computer Case Fan 120mm Cooling Case Fan for Computer Cases Cooling 15LED Red ($12.99 @ Amazon) Total: $587.74 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 10:36 EDT-0400 stick to the faster kit, you should be able to set it to close to its rated speed. otherwise it's fine. when you're mentioning someone, wait till you see their profile name and pic and click on it. CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597981 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Just now, Herman Mcpootis said: what a nice meme Go-to whenever someone makes a generic statement about "systems with [GPU] don't consume more than [wattage] CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 || LAPTOP: Dell XPS 15 7590 TABLET: iPad Pro PHONE: Galaxy S9 She/they Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597983 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Author @Herman Mcpootis oh. should I get the 3000mhz ram or 2666mhz Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11597997 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 46 minutes ago, Nstud said: @stefanDB thank you for the suggestion. The reason I don't want to cheap out on the CPU is because I plan on multi-tasking a lot. Do you think I will need that good of a processor for that? What do you consider multitasking? Generally RAM is going to be more of a bottleneck than the CPU. 14 minutes ago, OrbitalBuzzsaw said: PCPartPicker part list: https://pcpartpicker.com/list/FYFYQZ Price breakdown by merchant: https://pcpartpicker.com/list/FYFYQZ/by_merchant/ CPU: AMD - FX-9590 4.7GHz 8-Core OEM/Tray Processor ($89.99 @ Newegg) CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler ($149.99 @ Newegg) Motherboard: ASRock - 970A-G/3.1 ATX AM3+/AM3 Motherboard ($129.99 @ Amazon) Memory: Corsair - Vengeance 32GB (4 x 8GB) DDR3-1600 Memory ($649.99 @ Newegg Marketplace) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Video Card: MSI - GeForce GTX 1050 Ti 4GB GAMING X 4G Video Card ($204.98 @ Newegg Business) Case Fan: Thermaltake - Riing Plus 14 RGB TT Premium Edition (5 Fan Pack) 63.2 CFM 140mm Fans ($149.99 @ Amazon) Total: $3996.87 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 10:40 EDT-0400 PCPP says 561 watts It should say risk of fire with that motherboard selected CPU: Ryzen 9 5900 Cooler: EVGA CLC280 Motherboard: Gigabyte B550i Pro AX RAM: Kingston Hyper X 32GB 3200mhz Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: Gigabyte GTX 1050 PSU: Corsair SF750 Case: Streacom DA2 Monitor: LG 27GL83B Mouse: Razer Basilisk V2 Keyboard: G.Skill KM780 Cherry MX Red Speakers: Mackie CR5BT MiniPC - Sold for $100 Profit Spoiler CPU: Intel i3 4160 Cooler: Integrated Motherboard: Integrated RAM: G.Skill RipJaws 16GB DDR3 Storage: Transcend MSA370 128GB GPU: Intel 4400 Graphics PSU: Integrated Case: Shuttle XPC Slim Monitor: LG 29WK500 Mouse: G.Skill MX780 Keyboard: G.Skill KM780 Cherry MX Red Budget Rig 1 - Sold For $750 Profit Spoiler CPU: Intel i5 7600k Cooler: CryOrig H7 Motherboard: MSI Z270 M5 RAM: Crucial LPX 16GB DDR4 Storage: Intel S3510 800GB GPU: Nvidia GTX 980 PSU: Corsair CX650M Case: EVGA DG73 Monitor: LG 29WK500 Mouse: G.Skill MX780 Keyboard: G.Skill KM780 Cherry MX Red OG Gaming Rig - Gone Spoiler CPU: Intel i5 4690k Cooler: Corsair H100i V2 Motherboard: MSI Z97i AC ITX RAM: Crucial Ballistix 16GB DDR3 Storage: Kingston Fury 240GB GPU: Asus Strix GTX 970 PSU: Thermaltake TR2 Case: Phanteks Enthoo Evolv ITX Monitor: Dell P2214H x2 Mouse: Logitech MX Master Keyboard: G.Skill KM780 Cherry MX Red Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11598030 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 10 minutes ago, Nstud said: should I get the 3000mhz ram or 2666mhz 3000 or 3200 usually works best with ryzen https://www.asrock.com/mb/AMD/AB350M/index.us.asp#Memory memory support Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11598036 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Just now, dizmo said: What do you consider multitasking? Generally RAM is going to be more of a bottleneck than the CPU. It should say risk of fire with that motherboard selected Comes with fire extinguisher. That way they avoid the label Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11598037 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 2 minutes ago, dizmo said: What do you consider multitasking? Generally RAM is going to be more of a bottleneck than the CPU. It should say risk of fire with that motherboard selected You asked for a fire hazard? PCPartPicker part list: https://pcpartpicker.com/list/xzDmFt Price breakdown by merchant: https://pcpartpicker.com/list/xzDmFt/by_merchant/ CPU: AMD - FX-9590 4.7GHz 8-Core OEM/Tray Processor ($89.99 @ Newegg) CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler ($149.99 @ Newegg) Motherboard: ASRock - 970A-G/3.1 ATX AM3+/AM3 Motherboard ($129.99 @ Amazon) Memory: Corsair - Vengeance 32GB (4 x 8GB) DDR3-1600 Memory ($649.99 @ Newegg Marketplace) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Storage: Seagate - BarraCuda Pro 12TB 3.5" 7200RPM Internal Hard Drive ($436.99 @ SuperBiiz) Video Card: MSI - GeForce GTX 1050 Ti 4GB GAMING X 4G Video Card ($204.98 @ Newegg Business) Case: Cooler Master - MasterCase H500P ATX Mid Tower Case ($123.72 @ Amazon) Power Supply: Logisys - 575W ATX Power Supply ($24.99 @ SuperBiiz) Case Fan: Thermaltake - Riing Plus 14 RGB TT Premium Edition (5 Fan Pack) 63.2 CFM 140mm Fans ($149.99 @ Amazon) Total: $4145.58 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 10:58 EDT-0400 CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 || LAPTOP: Dell XPS 15 7590 TABLET: iPad Pro PHONE: Galaxy S9 She/they Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11598040 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Author does anyone see anything wrong with this build? PCPartPicker part list: https://pcpartpicker.com/list/4vMyq4 Price breakdown by merchant: https://pcpartpicker.com/list/4vMyq4/by_merchant/ CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($149.99 @ Amazon) Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($49.99 @ Newegg) Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory ($80.98 @ Newegg) Storage: Team - L5 LITE 240GB 2.5" Solid State Drive ($44.99 @ Newegg) Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card ($199.99 @ Newegg) Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case ($29.99 @ Newegg) Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($23.98 @ Newegg) Case Fan: Apevia - CF12S-BK 57.7 CFM 120mm Fan ($2.83 @ Newegg) Other: uphere 3-pack Long Life Computer Case Fan 120mm Cooling Case Fan for Computer Cases Cooling 15LED Red ($12.99 @ Amazon) Total: $595.73 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 11:14 EDT-0400 Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11598092 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 9 minutes ago, Nstud said: does anyone see anything wrong with this build? PCPartPicker part list: https://pcpartpicker.com/list/4vMyq4 Price breakdown by merchant: https://pcpartpicker.com/list/4vMyq4/by_merchant/ CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($149.99 @ Amazon) Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($49.99 @ Newegg) Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory ($80.98 @ Newegg) Storage: Team - L5 LITE 240GB 2.5" Solid State Drive ($44.99 @ Newegg) Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card ($199.99 @ Newegg) Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case ($29.99 @ Newegg) Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($23.98 @ Newegg) Case Fan: Apevia - CF12S-BK 57.7 CFM 120mm Fan ($2.83 @ Newegg) Other: uphere 3-pack Long Life Computer Case Fan 120mm Cooling Case Fan for Computer Cases Cooling 15LED Red ($12.99 @ Amazon) Total: $595.73 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 11:14 EDT-0400 it's fine. since you really seem to want fans for some reason, try these, RGB and comes with RGB strips. https://www.amazon.com/Wigbow-Infrared-Controller-Computer-Cooling/dp/B06X3VR53L/ref=sr_1_11?s=pc&ie=UTF8&qid=1533137210&sr=1-11&keywords=rgb+fan CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11598151 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 Author @Herman Mcpootis thank you you have been a huge help with my first PC Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11598176 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 1, 2018 4 hours ago, Nstud said: Try to stretch for Ryzen 2000, it's easily likely worth the price increase, as is the RX 580 at $249, at least for the long run, an RX 570 will still be fine at 1080p Also wouldn't trust mail in rebates PCPartPicker part list: https://pcpartpicker.com/list/wKsjNQ Price breakdown by merchant: https://pcpartpicker.com/list/wKsjNQ/by_merchant/ CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor ($169.89 @ OutletPC) Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($59.99 @ Newegg) Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory ($80.98 @ Newegg) Storage: ADATA - XPG SX6000 256GB M.2-2280 Solid State Drive ($62.89 @ OutletPC) Video Card: XFX - Radeon RX 580 8GB GTS XXX ED Video Card ($249.99 @ Amazon) Case: Rosewill - RANGER-M MicroATX Mini Tower Case ($23.45 @ Amazon) Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($45.59 @ SuperBiiz) Total: $692.78 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2018-08-01 14:13 EDT-0400 I edit my posts a lot, Twitter is @LordStreetguru just don't ask PC questions there mostly... Spoiler What is your budget/country for your new PC? what monitor resolution/refresh rate? What games or other software do you need to run? Link to comment https://linustechtips.com/topic/954724-help-with-pc-build/#findComment-11598648 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
