Im Buying a GPU urgent help
Arcana
i found here on our town selling his 2nd hand GPU for 169$ "Gigabyte GTX 960 G1 Gaming 4GB" is this worth to buy it? and i negotiate with him, i ask him if he wants to downgrade and he aggree im giving my "Sapphire r7 260x 2gb GDDR5" + 122$, should i go and take the offer?, please i need help first time to buy a 2nd hand GPU
https://www.gigabyte.com/Graphics-Card/GV-N960G1-GAMING-4GD-rev-10#ov
no. GTX 960 is about as fast as current gen 1050ti, which cost about $150 brand new.
unless that $ is CAD
Desktop benching:
actually im from ph i just using the google converter
Don't pay more than $100 usd for a 960 4gb
Fanboys are the worst thing to happen to the tech community World. Chief among them are Apple fanboys.
5 minutes ago, GoldenLag said:
Dont. You can get an R9 290x for about the same money. Its a better GPU and a better buy
i found a new guy selling his 2nd hand gigabyte gtx 970 for 150$/8,000 (in my country which is PH) do you think i should take it? plus additional sapphire r7 260x 2gb
That's pushing the limit a bit, but a much better deal than the 960.
Not an outstanding deal, but a fair one. If you can't find any better that's not bad at all
If you can find a 290x for less or the same it would be a better buy than the 970 due to the 970 practically only has 3.5GB of Vram, meanwhile the 290x has 4GB.
thanks! do you think my power supply Seasonic M12-II 520 Evo can handle the gigabyte gtx 970?
kinda rare to find here on our place tbh
If you cant find it. Look for the 390x. If you cant find that, then the 970 should be fine.
Yeah that won't be an issue. That's a solid psu and you'll have plenty of overhead still
alright thanks!
thanks alot!
alright thanks!
thanks alot!
That cards not all that much better then your card. I would keep yours. Your going to trade your card plus $100 cash?!
Firestrike
i7-8700k @5.0GHz w/ 1.30v, Corsair h100iv2, Gigabye Aorus gaming 7, 16GB(8x2) 2666MHz ddr4, Dual RX470's OC'd to 1390mhz(atm) in corssfire - liguid cooled with corsair h60's, 3.25 TB in Samsung SSD's, anidees white crystal cube case
Retired:
i5-4440k @3.2GHz, gigabyte ga-z87x-ud5h z87, 24GB DDR3, 3x1TB Seagate Baracuda HDD.
found already a new guy, which he sells his 2nd hand gigabyte gtx 970 g1, for 150$ + my card
But your basically going to get virtually no difference in performance
Nevermind thaught you had a 290x
Firestrike
Retired:
But the gtx cards not worth 150 plus your card it's maybe worth 150 period.
Firestrike
Retired:
You shouldn't of asked to trade cards plus that much cash. I would take that deal too cuz he can sell your card too and really get a good deal.
Firestrike
Retired:
then what should i ask to get then? hmm
$175 tops for that
Firestrike
Retired:
1 minute ago, O9B0666 said:
$175 tops for that
alright ill try it
But if you already asked em to trade your card plus $150 cash I don't see em taking $175 lol your cards worth more then $25.
Firestrike
Retired:
okay thanks for the help
