max refresh rates for vga at 1600x1200?
ImNotThere
buying a monitor, AOC E2070SWNL to be specific, some places list this as a 60 hz monitor but others say 60-90hz? it has no display port and hdmi only supports 60hz correct? so does that mean the VGA port supports 60hz+?
On 31/07/2018 at 12:24 AM, Glenwing said:
You're probably looking at horizontal refresh rate which is 60-90 kHz and refers to something completely different
Most places said 60-90 Hz but yeah that sounds like a mistake, thank-you!
On 31/07/2018 at 12:00 AM, Slottr said:
vga max is 70hz
Great thank-you!
On 31/07/2018 at 12:03 AM, johnny5c said:
HDMI isn't locked at 60Hz, HDMI 1.4 can do 1080p@144Hz.
This monitor doesn't have 1.4 afaik but thanks :)
