External WiFi antenna?
Solved by r4tch3t,
Yes. But finding one that will difficult. Search Google for USB OTG (on the go) WiFi adaptor. I found a couple but vibe with antennas so far.
Basically you need to find one that android will recognise. There are guides around aswell. Like this one seems to be ok and mentions WiFi repeaters aswell.
