Hello, I'm building a gaming PC with an i7 8700k and Geforce GTX 1080 ti. The graphics card is an open-air style card. I was looking for case recommendations. I need a case that looks good it has to be ATX and it needs very good airflow and needs to be good at staying cool. If you know about a case that might suit my needs, please tell me its name and a link if you can. Thanks so much!
https://linustechtips.com/topic/953229-atx-gaming-case/
Keep in mind: If you're using an AIO and want to front mount it, (assuming your 1080ti is a Strix, FTW3, Aorus, Duke, Lightning, Hall Of Fame or some over variation of a long GPU (over 300mm) you wont be able to use the Meshify C without modifying part of the front panel (the case is too short otherwise)
https://linustechtips.com/topic/953229-atx-gaming-case/#findComment-11592477
