Looking for fans that cost 20usd in total.One to be installed on a cooler master hyper evo 212 and another to be installed on the front of a BitFenix Shadow case.i want the fans to increase more air flow and quite and long-lasting.And is a second fan recommened on the cm hyper212 if a fx6300 is overclocked to 4.5ghz as i wanted to keep the temp. as low as possible.
https://linustechtips.com/topic/95309-two-fans/
Save up your money a little longer and get noctuas. Everyone can agree that , quiet, long lasting and pushing air only states noctua fans. The truth has been spoken.
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
https://linustechtips.com/topic/95309-two-fans/#findComment-1276600
A second fan won't make much difference on a 212 and adding a second fan will interfere with tall RAM like Corsair Vengeance/Dominator. As far as fans go the fan that comes on the 212 is fine so you don't need to replace it.
As far as what fan to get any of these will do nicely
http://www.frozencpu.com/products/14434/fan-924/BitFenix_Spectre_Pro_120mm_Fan_-_Black_BFF-SPRO-12025KK-RP.html?tl=g36c15s60
http://www.frozencpu.com/products/18997/fan-1190/Cougar_120mm_x_25mm_Vortex_Hydro_Dynamic_Bearing_Fan_-_Black_CFV12HB.html?tl=g36c15s60
http://www.frozencpu.com/products/13291/fan-874/Gelid_Solutions_Silent_12_120mm_x_25mm_Silent_Case_Fan_-_1000_RPM_FN-SX12-10.html?tl=g36c15s60
http://www.frozencpu.com/products/13307/fan-880/Gelid_Solutions_Silent_12_TC_120mm_x_25mm_Temperature_Controlled_Case_Fan_-_750_-_1500_RPM20C_-_42C_FN-TX12-20.html?tl=g36c15s60
http://www.frozencpu.com/products/8407/fan-524/Noiseblocker_NB-BlackSilentFan_XL1_120mmx25mm_Ultra_Quiet_Fan_-_1000_RPM_-_13_dBA.html?tl=g36c15s60
http://www.frozencpu.com/products/8408/fan-525/Noiseblocker_NB-BlackSilentFan_XL2_120mm_x_25mm_Ultra_Quiet_Fan_-_1500_RPM_-_21_dBA.html?tl=g36c15s60
http://www.frozencpu.com/products/16985/fan-1052/Silverstone_Air_Penetrator_AP122_120_x_120_x_25mm_Fan_-_SST-AP122.html?tl=g36c15s60
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/95309-two-fans/#findComment-1276607
https://linustechtips.com/topic/95309-two-fans/#findComment-1276618
Im not replacing juz thought of adding one more but i know waht u mean and im not using tall rams
Adding another fan doesn't really help performance much if at all.
Do you already have the system assembled?
https://linustechtips.com/topic/95309-two-fans/#findComment-1284416
Second fan on an evo won't make a big difference on temps (maybe 2-3 degrees), but...
It makes gaming completely silent. Two fans at low rpm are a hell of a lot quieter then one fan at high rpm. As far as the extra fan a coolermaster bladesmaster PWM will do fine. You can order the evo fan directly from coolermaster for 6.99 but they charge a lot for shipping (like 9 bucks or something). You don't put a non PWM fan on a evo though. That defeats the whole point of quieter operation.
You could put noctua's on the evo and it wouldn't cool any better. They push slightly less air at lower rpm (quieter). The evo fans are fine. As far as the front of a case. Any case fan will do. More expensive the quieter. Lower RPM that pushes a lot of air the better.
Under 20 bucks? Prob not doable. 23-25? Sure.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/95309-two-fans/#findComment-1284694
