New Headset Recommendation! Need help
I bought the hyper x revolver s and it just recently broke. I though of buying the cloud alphas but i recently found out about the Steel Series Arctis pro + gamedac .
Any thoughts on which one i should get or any other recommendations would be great .
For price anywhere below 300
https://linustechtips.com/topic/952781-new-headset-recommendation-need-help/
Cheap ass Sibera 200s should work fine.
I'm using the Asus Strix 2.0 and I'm happy with them, quality wise are top notch, with some external audio thingy *lazy to check out* you can get a really deep base out of them, of course with budget like this one you can easily fit the most expensive one's that has RGB, but still if you don't like them you can look around the Asus/Steelseries models that are higher than 150, they are all great
