6 minutes ago, Shiny_Gliscor said:
I recently finished my first waterloop and cleaned it completely with Mayhems blitz 1 and 2. Now after flushing it out and trying too boot the system the cpu reaches over 90 degrees after about 30 secs to a minute in bios. Does anyone know why that could be?
Did you put fresh thermal paste?
Is the pump working?
https://linustechtips.com/topic/952644-cpu-overheating/#findComment-11579232
20 minutes ago, Shiny_Gliscor said:
Yes I applied an entire tube of  .5 grams of kryonaut before putting the block on and i can here the pump humming.
Then maybe the fins on the cold plate are screwed and not transferring heat very well?
Or the Temp Sensor is busted.
What happens when you try to run Prime95 or something?
https://linustechtips.com/topic/952644-cpu-overheating/#findComment-11579303
The block is new and I can't run prime bcuz it shuts down immediately after booting into windows.
https://linustechtips.com/topic/952644-cpu-overheating/#findComment-11580290
Did you take the sticker off the block if there was one? If the pump is running and there's thermal paste there shouldn't be any issues.
https://linustechtips.com/topic/952644-cpu-overheating/#findComment-11580377
Pictures of your system and more information about parts will be helpful.
https://linustechtips.com/topic/952644-cpu-overheating/#findComment-11580636
