I was looking for a b350 mobo and I couldn't find one which supported 3000mhz ram, only 2666mhz, 2933mhz and 3200mhz. The thing is, I want to use a 2x4gb 3000mhz CL15, because if I go for the 3200mhz I have to get CL16, and going with 2666mhz is too "slow" for  the Ryzen 5 2400g that I'm planning to use in my build. So my question is, can I slow down the RAM clock speed from 3000mhz to 2933mhz?
https://linustechtips.com/topic/951845-downgrade-ram-speed/
Yes you can underclock in the BIOS, you will not get 2933mhz exact. As it is step speed.
Intel 12400F | 2x8 3000Mhz Corsair LPX | ASRock H570M-ITX  | Noctua DH-N14 | Corsair MP50 480GB | Meshilicious | Corsair SF600Fedora
Thanks let me know if I said something useful. Cheers!
https://linustechtips.com/topic/951845-downgrade-ram-speed/#findComment-11571459
