So, I'm building a pc and I am wondering if I can use this WIFI card ( https://www.gigabyte.com/Motherboard/GC-WB1733D-I-rev-10#ov ) on this motherboard ( https://www.msi.com/Motherboard/B350-PC-MATE.html ).
I'm using the Ryzen 5 2400g, which means no GPU, but if I would want to upgrade in the future with a discrete one, could I use both the GPU and the WIFI card?
https://linustechtips.com/topic/951838-need-some-help-with-ports/
Wifi card can go into the 1-2in slot right below or above the gpu and should fit depending on the gpu size. Should fit in the top one no problem with a gpu right below it
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Yup you're fine with that pair. The wifi card goes into the PCI-E X1 slot (you have two, one on the very top and one in the middle of the PCI-E stack) and a GPU would go into a PCI-E X16 slot (the big silver one second down from the top of the stack).
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
