Transporting a Liquid Cooled build
Go to solution Solved by DudefromHamburg,
draining the loop sure helps a lot :D.
Otherwise? get it yourself, and protect it like a newborn with loads of blankets, better yet get a 2nd person to hold it firm and drive slowly :)
17 minutes ago, G4m3r11 said:
Is there anything I have to do before transporting the PC to prevent leakage
No, your PC should be fine unless someone drops it hard.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
Is it a full custom loop or is it an AIO?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
11 minutes ago, G4m3r11 said:
Thanks, it's not a long journey so it should be fine then. Bidding ends in 3 days anyway, wish me luck.
Good Luck!
16 hours ago, tp95112 said:
If its an AIO just take it off, if its a custom loop then drain it and when it arrives to check for any cracks or fractures in the reservoir and check the tubing/fittings
It's collection only, so I have to go and get it, but as soon as I get it home I will drain the loop and fill it with some air overnight to see if any air pressure is lost.
