14 minutes ago, SAMMYBOI said:
First PC Build. Need help ironing out pieces. Getting everthing from memory express.
An RX 570 is a better buy than the 1060 6GB going by pricing on the part picker.
Also the display has free-sync
Left room for tax/shipping costs, you can easily add an SSD later, X470 also gets you StoreMI for that.
If you end up with extra cash maybe get a nicer case, or just don't use a case for a while to save up for that.
Buy this cheap/effective peripheral set at $49 CAD
https://www.amazon.ca/Redragon-S101-BA-Keyboard-Headset-Programmable/dp/B06ZYMQYCW/ref=sr_1_9?ie=UTF8&qid=1532379482&sr=8-9&keywords=Redragon
PCPartPicker part list: https://ca.pcpartpicker.com/list/CG3YLJ
Price breakdown by merchant: https://ca.pcpartpicker.com/list/CG3YLJ/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($244.99 @ Memory Express)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($172.75 @ Vuugo)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  ($196.99 @ Newegg Canada)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.75 @ shopRBC)
Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card  ($287.87 @ Amazon Canada)
Case: Deepcool - TESSERACT SW ATX Mid Tower Case  ($49.99 @ Amazon Canada)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon Canada)
Monitor: LG - 24MP59G-P 23.8" 1920x1080 75Hz Monitor  ($169.99 @ Memory Express)
Total: $1252.32
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567170
Mem express only
PCPartPicker part list: https://ca.pcpartpicker.com/list/Lf7Nvn
Price breakdown by merchant: https://ca.pcpartpicker.com/list/Lf7Nvn/by_merchant/
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($229.99 @ Memory Express)
CPU Cooler: Cooler Master - Hyper 612 Ver.2 44.2 CFM Rifle Bearing CPU Cooler  ($59.99 @ Memory Express)
Motherboard: MSI - Z370M MORTAR Micro ATX LGA1151 Motherboard  ($149.99 @ Memory Express)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($209.99 @ Memory Express)
Storage: ADATA - Ultimate SU800 512GB 2.5" Solid State Drive  ($139.99 @ Memory Express)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($399.99 @ Memory Express)
Case: Corsair - 270R ATX Mid Tower Case  ($69.99 @ Memory Express)
Power Supply: EVGA - SuperNOVA G1+ 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Memory Express)
Total: $1359.92
Generated by PCPartPicker 2018-07-23 17:02 EDT-0400
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567176
Just now, SAMMYBOI said:
Yea ik. Any luck with a good build?
There's a parts list, just find same/similar parts at memory express aside from the keyboard stuff and monitor
Total: $1252.32
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567204
You can judge how it compares to the others. Low end peripherals and cases aren't my thing, but you could get higher end ones.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($229.99 @ Amazon Canada)
Motherboard: Gigabyte - Z370M DS3H Micro ATX LGA1151 Motherboard  ($109.95 @ Vuugo)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($85.99 @ Amazon Canada)
Storage: *Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.95 @ Vuugo)
Video Card: Sapphire - Radeon RX 580 4GB PULSE Video Card  ($336.50 @ Vuugo)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($47.75 @ Vuugo)
Power Supply: Cooler Master - MasterWatt 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($58.99 @ PC-Canada)
Keyboard: Cooler Master - Lite L Wired Gaming Keyboard w/Optical Mouse  ($39.99 @ Newegg Canada)
Total: $1326.09
Generated by PCPartPicker 2018-07-23 17:09 EDT-0400
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567208
Total: $1326.09
Can I up the price to $1500 CAD with preferably a nvidia card
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567226
13 minutes ago, Firewrath9 said:
Mem express only
Total: $1359.92
Can you fit in a monitor keyboard and a mouse into that for $1500
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567236
How about this?
PCPartPicker part list: https://ca.pcpartpicker.com/list/D6s3Hh
Price breakdown by merchant: https://ca.pcpartpicker.com/list/D6s3Hh/by_merchant/
Motherboard: Gigabyte - B360 HD3 ATX LGA1151 Motherboard  ($109.99 @ Amazon Canada)
Memory: Crucial - Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory  ($186.33 @ Amazon Canada)
Storage: ADATA - Ultimate SU800 512GB 2.5" Solid State Drive  ($139.99 @ Amazon Canada)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($396.74 @ Amazon Canada)
Case: Corsair - 270R ATX Mid Tower Case  ($69.99 @ Amazon Canada)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($98.76 @ Amazon Canada)
Monitor: Acer - KG221Q 21.5" 1920x1080 75Hz Monitor  ($149.99 @ Amazon Canada)
Keyboard: Corsair - K55 RGB Wired Gaming Keyboard  ($69.99 @ Amazon Canada)
Mouse: Corsair - Harpoon RGB Wired Optical Mouse  ($46.12 @ Amazon Canada)
Total: $1497.89
Generated by PCPartPicker 2018-07-23 17:18 EDT-0400
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567244
1 minute ago, SAMMYBOI said:
Preference
I'll take that as no actual reasons. In which case I suggest nicer peripherals.
The 1060 6GB does not support Freesync, so you'll either have to get a way more expensive monitor, or a higher end Nvidia card for the experience to be equivalent.
The higher end Nvidia card would be the 1070 for $520, or the 1070 Ti for $600. Either of which would put you well outside of budget.
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567257
How can you have a preference when you seemingly don't know much about PC gaming?
Doesn't make any sense to spend the difference between an RX 570 and 1060 6GB for gaming.
Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card  ($287.87 @ Amazon Canada)  vs $400 CAD
and then you also lose out on free-sync which may be useful.
https://linustechtips.com/topic/951383-first-pc-build/#findComment-11567274
