My current gpu cooler is malfunctioning and I refuse to buy replacement gpu fans because they cost 35 aud each. I have an aftermarket 980 ti from gigabyte and was looking for replacement coolers, anything will work for now. What should I get?
Sennheiser HD600 Logitech G304 White Anne Pro 2 LG27UL500
Ryzen 5 3600 + MSI B450i Gaming Plus AC in Fractal Design Nano S
https://linustechtips.com/topic/951340-replacement-gpu-cooler/
I would expect any replacement is going to cost AT LEAST as much as those stock replacements, as you need something that fits that particular board so that it cools the RAM and VRMs too.
https://linustechtips.com/topic/951340-replacement-gpu-cooler/#findComment-11566781
Hi, the PCB looks the exact same as the reference 980 ti from my perspective so wouldnt the silver titan cooler work? Thanks
https://linustechtips.com/topic/951340-replacement-gpu-cooler/#findComment-11567206
Its been years since I looked at after-market GPU coolers so in all honesty, I don't know.
I should imagine so long as it matches EXACTLY and cools everything necessary.
You might have better look Googling existing users of that cooler, I couldn't find it from the description you gave.
https://linustechtips.com/topic/951340-replacement-gpu-cooler/#findComment-11567302
