Weird connection
Go to solution Solved by NelizMastr,
2 minutes ago, dovpei said:
Its lenovo v520s-08ikl desktop with b250 motherboard. So what exactly do i need to have to get the ssd and hdd connected?
One of these.
https://www.ebay.com/itm/Lenovo-Thinkcentrer-Mini-4P-V520-B250-Q270-Hard-HDD-double-2-SATA-Power-Cable/223035616920?hash=item33edf56e98%3Ag%3A5gUAAOSwZrhaYWjf&_sacat=0&_nkw=lenovo+v520+sata+cable&_from=R40&rt=nc&_trksid=m570.l1313
It's a proprietary motherboard, so you plug the power cables directly into the motherboard so you can connect more SATA devices. You'll have to find one online that's compatible. Is this a Medion/Peaq/Lenovo PC by any chance?
The cable on the picture is mini SATA, used for optical drives.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/951193-weird-connection/#findComment-11565417
https://linustechtips.com/topic/951193-weird-connection/#findComment-11565429
One of these.
https://linustechtips.com/topic/951193-weird-connection/#findComment-11565437
https://linustechtips.com/topic/951193-weird-connection/#findComment-11565448
Okay thanks a lot. This.will work with samsung 860 evo right?
SATA is SATA.
https://linustechtips.com/topic/951193-weird-connection/#findComment-11565453
