So I've had this R9 390 since July 2016, and I've had no issues with it until recently. The card stopped working randomly in the middle of a gaming session, and I used this as an excuse to build my new PC now instead of later in the year. However, I planned on giving my old pc to a friend, and this has stopped me from doing that. I looked up all the possible issues and I came across reflowing, so I took my time and did the research, and eventually learned that this was a temporary solution. I tried it and succeeded, for about 3 weeks, then my computer would start to crash whenever the card was put to work (playing games etc). I've tested it in different systems, with the same results. I reflowed it again and it started to work properly, for about 5 days before the same issues started appearing again. The system is totally fine until I load into an overwatch match (or other games, except for minecraft w/shaders. This doesn't cause the gpu to crash even when pushing it to 70+% usage), then the screen goes black and the computer freezes. I tried a 3rd reflow with no success. However, I undervolted the card by about 100mv, and was able to play overwatch and other gpu demanding games for roughly 5-10 minutes before the computer crashed again. My conclusion is that the card becomes unstable whenever it draws too much power. Is there any way to fix this or should I just trash it?
https://linustechtips.com/topic/950692-xfx-r9-390-issues/
"Reflowing" with a heat gun or oven is total BS. See LTT and Louis Rossmann videos below. I'd say recycle the card, get a 1050Ti or similar.
"Not breaking it or making it worse is key."
"Bad choices make good stories."
https://linustechtips.com/topic/950692-xfx-r9-390-issues/#findComment-11560966
17 minutes ago, Coriander said:
You could drop the power limit to like 50%, but it's probably just gone
At least RX 570s/580s are down in price
https://pcpartpicker.com/product/jkFXsY/asus-radeon-rx-580-8gb-dual-video-card-dual-rx580-o8g
https://linustechtips.com/topic/950692-xfx-r9-390-issues/#findComment-11560967
3 minutes ago, Coriander said:
I've been looking at the Sapphire RX580 Pulse, it's going for $299. Is Sapphire a good brand? I haven't heard too much about them.
Sapphire is generally the go to AMD card maker.
But you might as well save $50 on that asus card above.
Only thing is, it won't be much of an upgrade over the 390's performance.
https://linustechtips.com/topic/950692-xfx-r9-390-issues/#findComment-11561050
1 minute ago, Streetguru said:
I heard Asus has terrible customer service, which makes me a bit sketched lol. On the topic of brands, which gpu brand is the most reliable in terms of customer service and longevity? I don't want another card to burn out after 2 years of use (literally right as soon as my xfx warranty expired, rip).
https://linustechtips.com/topic/950692-xfx-r9-390-issues/#findComment-11561071
all the makers aren't bad, I've ran ASUS, PNY, XFX, and some old AMD only brands.
I ran my asus 970 for almost 3 years balls to the walls and it was fine. The PNY is a 9800GTX+ the AMD brand I can't remember is on a hd 5770 both those have been running for half a decade or more.
Just look and see if lots of people are having issues with that model before you buy.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/950692-xfx-r9-390-issues/#findComment-11561079
I was able to drop the power by 41% in the radeon settings. This made the card fully functional again with little to no drop in performance. However, I doubt it will last more than a few weeks lol.
May also be that something in the VRM died maybe. Either way it'll make a good wall decoration.
https://linustechtips.com/topic/950692-xfx-r9-390-issues/#findComment-11561205
