Hello everybody, I need your help...
I have a budget of 650€ and I want to upgrade my pc.
Current Specs:
Asus p8b75-m lx
Intel i3 3220
8 GB DDR3
Gigabyte GTX 960
Intenso 128GB SSD
WD Green 1TB HDD
What I'm planning on doing:
ASROCK B360M-HDV
Intel i5-8400
(This is where I need help because I'm confused)--> DDR4 ram - How do I find it and what do I choose???
What is the difference between SS/DS and the meaning of those
I'm planning on buying 8GB of ram.
And since GTX1070 is out of the budget i think GTX1060 would suffice.
Is this good enough? If you have any suggestions please leave them here. I appreciate the opinion. Since I'm new to building a PC. I need your help.
https://linustechtips.com/topic/950597-hello-everybody-i-need-your-help/
48 minutes ago, |Spice| said:
But why?
Becas more perfromace Cheaper and better than an 1060. Also do you know thares a amazing site calt PCpartpicker.
https://pcpartpicker.com
Edited by colonel_mortis
Remove political remark - please don't make off hand comments which can turn into flame wars
"i reject your reality and substitute my own"
          --- Workstion --- GamePc ---
"College great Dropout Engineering"
1 minute ago, |Spice| said:
Hmmmm 3770 isn't even on the PCPartPicker...
Yes its a older cpu that can fit in your motherbord. Look at your local second hand market. Price around 100 USD is oke for 80 its steal and than add 360 for a 1070
A'ight, Thanks man! I'm from Europe so i can be kinda hard to find something that isn't popular or old
The 3770 is an i7 from the generation of your current CPU, so it will fit in your current Mainboard. Since you dont have a Z77 Board it would not make sense to get a 3770K Version, but the 3770 is still a VERY capable CPU, for gaming anyway. You can buy one for about 100 bucks on ebay.
EDIT: Since you're from europe, are you from germany? Then I could help you find something.
Edited by zerosquared
Ebay will certainly do.
PPP won't show parts that aren't compatible with each other (as long as the compatibility filter is on)
You might need to remove some parts for it to show up, like the motherboard, for example
5b53b4a62967a_Screenshot_2018-07-22ChooseACPUCooler-PCPartPicker.png.8d021fc617d76ca0baadcb841ab287d7.png
Here's the CPU, if you still can't find it
