ok so im looking at doing a new build. it will be watercooled in the long run but for now will be air cooled. the computer will be used for gaming/ home theater as well as general use facebook and youtube etc. i am trying to future proof it abit without going way out of budget (dont have a specific number set) currently i am using a hp pavillon with a i5 yes a labtop. i have had the labtop since the beginning of windows 8 and it is still somewhat very good for what i use it for.
parts im looking at
Intel - Core i7-8700K 3.7GHz 6-Core Processor
Cooler Master - Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler
Asus - ROG MAXIMUS X HERO (WI-FI AC) ATX LGA1151 Motherboard
G.Skill - Ripjaws V Series 16GB (1 x 16GB) DDR4-3200 Memory
Western Digital - Blue 1TB M.2-2280 Solid State Drive
Seagate - BarraCuda Pro 6TB 3.5" 7200RPM Internal Hard Drive
MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card
Thermaltake - Core W100 ATX Full Tower Case might also add the p100 as well.
Corsair - 850W 80+ Platinum Certified Fully-Modular ATX Power Supply
oh and windows 10
comes in around 3800 dollars
what does everyone think. i am debating between a tv or a wide screen monitor for it. but cant decide. i only have a bachelor apartment. and the width of the apartment is only 9.5 feet. would a 38" monitor do or would i be better of sacrifising quality for smaller size
also any other tips would be great.
https://linustechtips.com/topic/950073-help/
@truckerlenny
You need to expand on your use case quite a bit. Are you planning to sit away from it, call it "TV Distance", or are you just looking for a large screen for your gaming computer? That dictates a lot.
As for "Future-proofing", that doesn't actually mean buying the absolute top of the line. What it means, in the current market, is the easiest to upgrade core components & best price/performance of the add-in cards. As the point is to upgrade those when new Standards roll out, since there is no forward-standard solutions. In the current market, that means either the best VRMs on a X470 boards w/ either a 2600 or 2700 Ryzen. Or you wait for the 8c Coffee Lake part in a couple of months, on whatever the best motherboard available.
Then you pair that with a great PSU and the best monitor for your task. Then you build the rest of the system around that. It's why your Use Case details matter.
https://linustechtips.com/topic/950073-help/#findComment-11555968
1 hour ago, Sernefarian said:
im trying to find gpu that are compatible with a ekwb water block alot are not
https://linustechtips.com/topic/950073-help/#findComment-11556245
as well as stick to 1 16 gb stick of memory incase i decide to add more in the future. i have no idea on how to tell which m.2 is better
https://linustechtips.com/topic/950073-help/#findComment-11556254
1 hour ago, Taf the Ghost said:
@truckerlenny
both. i will be using it for watching movies shows from a tv distance, as well as for gaming.  i meant future proofing as in i wont be upgrading for at least another few years 4-5 for sure. considering this one is about 5.5 years old now and has served me quite well.
https://linustechtips.com/topic/950073-help/#findComment-11556261
I'd go for a non-curved, greater than 32 Inch monitor. They're expensive, but that's the core component you'd want to settle on.
https://linustechtips.com/topic/950073-help/#findComment-11556320
ive decided to hold on the monitor side of things for now to see if someone comes out with a 55"+ tv with hdmi 2.1 and a 120 hz. hopeful. 32 inch is just not big enough and most monitors dont have wall mounting capabilities i will buy a cheap 1080p monitor in the interm
https://linustechtips.com/topic/950073-help/#findComment-11556634
