Posted July 18, 2018 Where is the default location for the snipping tool in Windows 10? When I click the shortcut for taking a snip, It doesn’t save it in pictures or screenshots? This only happens when I use the keyboard shortcut when I use the app and select the part that I need to capture it will ask me to choose the save location. AMD Ryzen 1700x Asus Crosshair VI Hero GTX 1070 16gb RAM 2333Mhz 500gb Samsung SSD Windows 10 & Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 You have to save it at which point you can choose where it goes. You can also just "control + c" and then paste it elsewhere. Many apps support pasting into them and it will work as expected (forum included). Solve your own audio issues | First Steps with RPi 3 | Humidity & Condensation | Sleep & Hibernation | Overclocking RAM | Making Backups | Displays | 4K / 8K / 16K / etc. | Do I need 80+ Platinum? If you can read this you're using the wrong theme. You can change it at the bottom. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 Author 2 minutes ago, Ryan_Vickers said: You have to save it at which point you can choose where it goes. You can also just "control + c" and then paste it elsewhere. Many apps support pasting into them and it will work as expected (forum included). No, I don't mean when I use the app. It happens when I only use the keyboard shortcut after I snip a part of the screen I don't get any save as or option, it just disappears. When I check on MyPuctures folder I can't find it either. AMD Ryzen 1700x Asus Crosshair VI Hero GTX 1070 16gb RAM 2333Mhz 500gb Samsung SSD Windows 10 & Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 4 minutes ago, Pavilion said: No, I don't mean when I use the app. It happens when I only use the keyboard shortcut after I snip a part of the screen I don't get any save as or option, it just disappears. When I check on MyPuctures folder I can't find it either. I'm not sure what you mean... I'm not aware of any system-level shortcuts that use snipping tool without launching the app Solve your own audio issues | First Steps with RPi 3 | Humidity & Condensation | Sleep & Hibernation | Overclocking RAM | Making Backups | Displays | 4K / 8K / 16K / etc. | Do I need 80+ Platinum? If you can read this you're using the wrong theme. You can change it at the bottom. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 Author 1 minute ago, Ryan_Vickers said: I'm not sure what you mean... I'm not aware of any system-level shortcuts that use snipping tool without launching the app Check it click on your keyboard, Win + SHIFT + S AMD Ryzen 1700x Asus Crosshair VI Hero GTX 1070 16gb RAM 2333Mhz 500gb Samsung SSD Windows 10 & Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 3 minutes ago, Pavilion said: Check it click on your keyboard, Win + SHIFT + S Ah yes, I did some looking around and found that mentioned as a footnote on one site. I tried it and experienced the same problem. Perhaps the feature just doesn't work? I feel like it would be more talked about and more well-known if it did as that is quite handy I know when you Win + print screen it saves it into ~Pictures/Screenshots but that's not working for this Solve your own audio issues | First Steps with RPi 3 | Humidity & Condensation | Sleep & Hibernation | Overclocking RAM | Making Backups | Displays | 4K / 8K / 16K / etc. | Do I need 80+ Platinum? If you can read this you're using the wrong theme. You can change it at the bottom. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 Author 2 minutes ago, Ryan_Vickers said: Ah yes, I did some looking around and found that mentioned as a footnote on one site. I tried it and experienced the same problem. Perhaps the feature just doesn't work? I feel like it would be more talked about and more well-known if it did as that is quite handy I know when you Win + print screen it saves it into ~Pictures/Screenshots but that's not working for this Yeah, it's unfortunate, because I have the same issue, but the Print screen is working for me, it could be that this feature is not working at all. AMD Ryzen 1700x Asus Crosshair VI Hero GTX 1070 16gb RAM 2333Mhz 500gb Samsung SSD Windows 10 & Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 5 minutes ago, Pavilion said: Yeah, it's unfortunate, because I have the same issue, but the Print screen is working for me, it could be that this feature is not working at all. I actually wrote a program specifically for this purpose because I didn't realize Windows had this built in. I guess in a way, it still doesn't so I'll keep using my own for now Solve your own audio issues | First Steps with RPi 3 | Humidity & Condensation | Sleep & Hibernation | Overclocking RAM | Making Backups | Displays | 4K / 8K / 16K / etc. | Do I need 80+ Platinum? If you can read this you're using the wrong theme. You can change it at the bottom. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 Author 2 minutes ago, Ryan_Vickers said: I actually wrote a program specifically for this purpose because I didn't realize Windows had this built in. I guess in a way, it still doesn't so I'll keep using my own for now Can you share it with me? I would like to try it AMD Ryzen 1700x Asus Crosshair VI Hero GTX 1070 16gb RAM 2333Mhz 500gb Samsung SSD Windows 10 & Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 11 minutes ago, Pavilion said: Can you share it with me? I would like to try it Sure. It's pretty basic. Just run it and it hides in the background. There's no visual feedback to show it's working. Just hold down both alt keys (I chose this since it's not something that would ever be done by accident or conflict with other apps), drag over the area you want, and let go. The clipping will appear as a bitmap on your desktop. Screenshot.exe Solve your own audio issues | First Steps with RPi 3 | Humidity & Condensation | Sleep & Hibernation | Overclocking RAM | Making Backups | Displays | 4K / 8K / 16K / etc. | Do I need 80+ Platinum? If you can read this you're using the wrong theme. You can change it at the bottom. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2018 Author 17 minutes ago, Ryan_Vickers said: Sure. It's pretty basic. Just run it and it hides in the background. There's no visual feedback to show it's working. Just hold down both alt keys (I chose this since it's not something that would ever be done by accident or conflict with other apps), drag over the area you want, and let go. The clipping will appear as a bitmap on your desktop. Screenshot.exe Thanks, I will give it a try and give you my feedback AMD Ryzen 1700x Asus Crosshair VI Hero GTX 1070 16gb RAM 2333Mhz 500gb Samsung SSD Windows 10 & Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 15, 2018 On 2018-07-18 at 2:20 PM, Pavilion said: No, I don't mean when I use the app. It happens when I only use the keyboard shortcut after I snip a part of the screen I don't get any save as or option, it just disappears. When I check on MyPuctures folder I can't find it either. I have solved this (or rather, someone else told me how it works ). When you use that, the area you selected gets copied to the clipboard, so you could paste in paint, etc. Rather disappointing imo and kind of missing the point. To be clear, I wouldn't want them to take that away, as sometimes you want it just in the clipboard, but it would be nice if it also saved a copy somewhere automatically. Win + Printscreen saves a file but only takes the whole screen, and this Win + Shift + S takes just part of the screen but won't save a file. Why can't we have both Microsoft? Solve your own audio issues | First Steps with RPi 3 | Humidity & Condensation | Sleep & Hibernation | Overclocking RAM | Making Backups | Displays | 4K / 8K / 16K / etc. | Do I need 80+ Platinum? If you can read this you're using the wrong theme. You can change it at the bottom. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
