Hello guys.
I really need your help. So For the past month I have been experiencing very weird Frame Rate issues and random frame rate drops/stuttering. Basically every 5-15 seconds my frames drop and I get a stutter, which is very annoying. So I ran some tests. My GPU and CPU usage looked pretty normal, same with the temps. I tried lowering my GPU overclock, but that didn't help. So I tried disabling my CPU overclock. That too didn't help. While running a Fire Strike Extreme Stress Test, I found that, according to the charts, every 10-20 seconds or so my CPU clock speeds dropped drastically, from 4.5GHz to anywhere from 3.6GHz to 1.4GHz. This really shocked me. Why was my CPU doing this? The CPU usage, according to CAM, was in the 40%-70% region, meaning it should have stayed at it's maximum clock speed, right? When my PC is idle, I have seen my CPU do this, where it'll drop from it's normal 4.8GHz clock speed to around 2GHz. But I thought it only did that because it was idle. How can I fix this? Could this be the cause of my random frame drops in games? Please, help!
Specs:
i7 7700K
ASUS Maximus IX Formula
32GB of RAM
GTX 1080Ti
1440p 144Hz Display
Thank you5b4e5dda26d50_Screenshot(11).thumb.png.6f0f6211e2253cb56b21a72b602dd807.png
Are you using the stock cooler? Make sure it's properly seated and the CPU is not over heating. I've seen this happen a ton.
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
Down clocking is generally temperature related. Also an option is you might not have high enough voltage on the overclock, but it's still enough to not let it crash during benchmarks yet
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
I'm using an NZXT X52 cooler. My temps seem fine, but if I can't fix my problem before this weekend I'll go ahead and open it up...
Thanks you
From what I can tell my temps aren't too high. I ran a 20 minute Aida 64 stress test and for the most part my CPU temps were below 70c. I thought maybe my CPU could not be getting enough voltage, but for that FireStrike stress test, I had loaded Optimized Defaults in my BIOS. So wouldn't the optimized default voltage be enough for stock clock speeds?
The way that's worded... Did you put an oc on your cpu and left it set to auto voltage?
Main Rig
Plex Server WIP
Sorry if I worded that horribly. No, loading Optimized Defaults in the BIOS resets everything. So there was No CPU oc, and the voltage would have been set to auto.
8 minutes ago, wojtepanik said:
use intel update software, flash bios, maybe vrms are overheating or something on the board? what psu you have?
I'm not sure how to check my VRM temps. My PSU is a EVGA G3 1000watt, so should be plenty of power for my system?
should be, touch everything and check if anything on your motherboard is heating too much, vrms are around cpu socket, there is also a intel diagnostic tool, it checks everything about the cpu
Ok. And it would seem as though the Intel Diagnostic Tool download no longer exists (it leads me to an 'Error: Page Not Found' page when I click download)
i did 2 days ago... lemme check
https://downloadcenter.intel.com/downloads/eula/19792/Intel-Processor-Diagnostic-Tool?httpDown=https%3A%2F%2Fdownloadmirror.intel.com%2F19792%2Feng%2FIPDT_Installer_4.1.0.28_64bit.exe
