Adjust the TVs image/picture settings.
https://linustechtips.com/topic/948880-problems-with-m-mini-pc/#findComment-11544835
38 minutes ago, enchaL said:
Can you tell me where in the TV settings like wich label.
Each TV calls it a different name, my 32in Panasonic just calls it "size 1" and "size 2", under the advanced picture settings.
Some have a "zoom" option, just check each and every setting in your TV, under "picture" or "image" setting or advanced settings.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/948880-problems-with-m-mini-pc/#findComment-11545626
