How to fix signal problems AV reciever
Solved by Slottr,
Can you try a different input port aside from the PC one?
Also, I've had a similar issue and a factory settings reset fixed it for me - different receiver though.
Featured Topics
DoughmanX_HD ·
Posted in Windows0 -
220VoltsallCore ·
Posted in Operating Systems1 -
Ridoheru ·
Posted in Graphics Cards0 -
EpicAAron ·
Posted in General Discussion0 -
3
Alexis-Ms_Sun21 ·
Posted in Troubleshooting0 -
2
Cramig88 ·
Posted in New Builds and Planning12 -
Ghostsanonymous ·
Posted in Displays3
