Cpu 8 pin compatibility
Go to solution Solved by Lurick,
It's a 4+4 connector so you just use the one half of the connector and it will work just fine.
Hello
I have finished building my budget build and just realised that my psu is to weak.
I've seen a decent looking psu (Thermaltake TR2 Series 600 W ) and saw that it has a 8 pin cpu connector.
But my sandy bridge motherboard only has 4 pin port.
Will the psu still work with my system?
Sorry if this question is stupid and I'm overlooking something.
https://linustechtips.com/topic/948112-cpu-8-pin-compatibility/
1 minute ago, Friendlymurderingtype said:
Thank you very much and sorry for the bother
No bother, better to ask to be sure than wind up with something that doesn't work :)
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/948112-cpu-8-pin-compatibility/#findComment-11537766
Just a note, the TR2 is NOT a good PSU... It's an older group regulated design...
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
https://linustechtips.com/topic/948112-cpu-8-pin-compatibility/#findComment-11538468
