Which do you prefer? I got a Nexus 7 2013 for xmas and i'm running stock android 4.4.2 and was wondering if I should get CM11. What are the benefits of CM11 over stock?
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/94638-cm-or-stock/
If you like stock, CM is just that with a few more powerful UI elements and tools built in.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/94638-cm-or-stock/#findComment-1268722
Agreed, CM is just better
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/94638-cm-or-stock/#findComment-1268761
I like stock if the device is up to date on Android versions as they are usually more stable than custom roms. I only use custom roms if the Android version that I want is not available on stock firmwares.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/94638-cm-or-stock/#findComment-1268773
I would say wait at the moment. CM 11 has only just come out and while it is pretty stable, it still does not have all the features that you would expect and some things are a bit buggy. When a release candidate or stable build comes I would suggest updating it then but until then I would wait.
My rig: i5 2500k, MSI Z77A G45, Gainward GTX 980 Phantom, 8GB Corsair Vengeance, OCZ ZT series 750W PSU, 1TB HDD, 800D, fully water cooled. I am currently working on modding my HAF 912+ to fit a custom loop, here is the build log: http://linustechtips.com/main/topic/165963-project-viridis-water-cooled-haf-912/
https://linustechtips.com/topic/94638-cm-or-stock/#findComment-1276217
Since you have a Nexus, Stock 4.4.2 & Xposed with GravityBox. Not that I'm saying CM isn't stable, but with this setup, you get all the neat features from a custom rom as well as the stability. Xposed is great because everything is through modules, so you can enable or disable features completely to your liking. If you want PrivacyGuard like in CM, I'd recommend XPrivacy with Xposed since it's pretty much Privacy Guard but better as it's much more specific with permissions management.
https://linustechtips.com/topic/94638-cm-or-stock/#findComment-1278337
