Ok first let me say this. I am not buying everything right now and might not buy anything for a few months.
I also am debating 2 things. Should I buy a prebuilt system from somewhere like I buy Power or build it myself (my current build is self built)
I am delaying on looking at CPUs and GPUs untill a later date because I won't have the cash for them untill later. So what I was looking at for now is just a Case and Fans/Coolers, Motherboard, PSU, Ram, and Possibly the Hard Drive.
I am trying for a Green Build. My first PC was Red my current one is blue.
This is what I have so far that I was thinking about.
Raidmax - Viper GX ATX Mid Tower Case
Asus - PRIME X299-A ATX LGA2066 Motherboard
Still looking at Coolers/Fans Suggestions would be helpfull
Ram I want 32GB of some Ram that will go good with the color Green. ( I plan to play games but also host small 2 to 5 man servers on my machine for me and my friends)
EVGA - SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply
As for the Storage I was wondering if I should go SSD/Hard Drive or just a Large SSD. and if I do go the Dual SSD/ HD how large should I make the SSD? I was thinking 250+ was OK as that would let me store games I want to play quicker on the SSD while a 2TB HD would cover the stuff that is ok otherwise.
GPU and CPU are gonna be looked at later as I have read they are gonna be coming out with new ones in the next few months.
https://linustechtips.com/topic/945465-startup-help/
3 minutes ago, Neo Blackheart said:
What do you need your PC for and what is your budget/country?
And what monitor resolution/refresh rate for gaming if any?
https://linustechtips.com/topic/945465-startup-help/#findComment-11513513
I was thinking of a I7 actually. Not going TOP of the line GPU was likely gonna wait for the next batch of GPUs to hit from Nvidia which I hear they should be out near the end of this year early next year so I was gonna go with a 1080 when the new ones come out as they should drop a decent amount when the new ones hit.
https://linustechtips.com/topic/945465-startup-help/#findComment-11513625
8 minutes ago, Firewrath9 said:
Then why do you have a x299 mobo?
By the way cant find any gren ram or mobo for cheap
i7 Extreme exists
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/945465-startup-help/#findComment-11513635
1 hour ago, Neo Blackheart said:
Its a Gaming PC in the US. As for my Budget I really am trying to stay below 2k but I know CPU and GPU will push that boundry a good bit.
And I have No idea on the Resolution I am gonna go with a Dual Monitor Setup I have to buy them as well.
What sort of frame rate are you wishing to target?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/945465-startup-help/#findComment-11513636
2 minutes ago, Firewrath9 said:
But they sre 500$
You could save on the GPU...
But yes, X299 is a bad idea...
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/945465-startup-help/#findComment-11513647
