Hi friends.
I found a random old HP XW4400 PC. Only it has no RAM. I don't know what RAM to buy. I can buy the original HP DDR2 (SDRAM) for €21 which is very expensive because of shipping, the actual price is €13. I can also buy this https://www.amazon.de/dp/B0087NGX4E/ref=asc_df_B0087NGX4E1530878400000/?tag=pricewatch-21&creative=22662&creativeASIN=B0087NGX4E&linkCode=df0&language=nl_NLDDR2 from Micro Memory, would this work with my PC? My next question is: what CPU can I upgrade to? It currently has an E6600 Core2Duo. It's socket 775 with chipset 975X. I've looked around online but I can't really find anything. I would like to upgrade to a Core2Quad or even XEON but I don't know what would work. If anyone know please tell me. Thanks you all :)
https://linustechtips.com/topic/945093-old-hp-ramcpu-advice/
1 hour ago, Yasin40 said:
Hi friends.
This is an old workstation, you will need ECC RAM to max out the ram at 8GB, it will take non-ECC, but only up to 2GB of ram.
You will need to update the BIOS and then the max CPU the system will accept is a QX6800, no Xeons.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/945093-old-hp-ramcpu-advice/#findComment-11510524
get ECC ram, it does offical support 2GB sticks of ECC ram, get something generic on on HPs QVL
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/945093-old-hp-ramcpu-advice/#findComment-11510583
