Singe pixel line along top edge of maximized programs
4 minutes ago, MattShnoop said:I re-enabled all of my startup programs, and I still don't see the issue.
Therefore it must not be being caused by any of these programs.
It must be something in that "System Services" box.
Note, when I selected Diagnostic startup, it automatically jumped down to Selective Startup, just with some stuff disabled.
It's unlikely that a built in Microsoft service is causing this, so the best way to find out which is which is to enable everything on the general tab > selective startup, then switch to the Services tab and tick the box "hide all Microsoft services" at the bottom.
What's left should be disabled one at a time, with your least known (or least used) services first, until you're able to determine which is causing it.
