How To Cable Manage A PSU?
Supahh
Hey, I recently copped a 750w rgb power supply, but the only problem is, is that my case (Corsair Spec Omega White) isn't very good for cable management, there is almost no room at the back to put cables in otherwise the back panel won't fit in.
If I put the PSU cords at the front then the problem currently is, is that I have so many wires that some are underneath my GPU fan that the right fan doesn't even spin.
It also isn't the best looking, so any help?
CPU: Intel i7-8700
GPU: MSI GTX 1060 6GB GAMING X
Monitor: HP OMEN 25 144hz
RAM: 8GB G Skill
Motherboard: MSI B360 Gaming Arctic
Storage: 2TB Barracuda
Start-up: Samsung 250GB SSD
Case: Corsair Spec-Omega White
PSU: ThermalTake 750W Fully Modular RGB
Keyboard: Razer Blackwidow Tournament Edition X Chroma V2
Mouse: Razer Deathadder / Logitech G502
Speakers: Logitech Z200 White / Beats Earphones
you can try hiding the cables behind or under the drive bays.
Assuming that power supply you picked up is modular, only use what you need, and try to be minimalistic. Generally speaking you don't want to cable manage your psu cables on top of the psu, just seems silly, route what you can behind it(some cases don't have a lot of room but it usually works out, even with a little elbow grease getting the back panel back on). Hide what you can behind and under the drive bays as well.
Good luck.
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
Good luck.
When I built the pc, I wasn't sure on how many cables I'd need as I'm a first time builder and now I'd have difficulties to remove the un-used wires as some of the wiring may unplug without knowing.
CPU: Intel i7-8700
RAM: 8GB G Skill
Take the time to go through it, ask questions and get it right. Proper cable management is worth the time it takes :)
