Help me to improve
Go to solution Solved by Jurrunio,
35 minutes ago, Jajahhdjj said:
around 90,000INR
From Amazon:
PCPartPicker part list: https://in.pcpartpicker.com/list/F4rtWD
Price breakdown by merchant: https://in.pcpartpicker.com/list/F4rtWD/by_merchant/
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (₹14200.00 @ Amazon India)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  (₹5399.00 @ Amazon India)
Monitor: Dell - SE2416H 23.8" 1920x1080 60Hz Monitor  (₹10715.00 @ Amazon India)
Sub-Total: ₹30314.00
Generated by PCPartPicker 2018-07-07 09:22 IST+0530
From MDComputers
CPU: AMD Ryzen 5 2600 ₹15620 https://mdcomputers.in/amd-hexa-core-ryzen-5-2600.html?search=ryzen 5&description=true
Mobo: Asus B350-F  ₹10600 https://mdcomputers.in/asus-rog-strix-b350-f-gaming.html
HDD: Toshiba P300 2TB ₹4700 https://mdcomputers.in/toshiba-p300-2tb-hdwd120uzsva.html
GPU: Inno3D GTX 1060 3GB GDDR5 X2 ₹18700 https://mdcomputers.in/inno3d-gtx-1060-3gb-gddr5-x2-n106f-2sdn-l5gs.html
Case: Corsair SPEC 4 Black/Grey ₹2950 https://mdcomputers.in/corsair-mid-tower-spec-4-black-grey-cc-9011109-ww.html
PSU: Cooler Master MASTERWATT 550W ₹4650 https://mdcomputers.in/cooler-master-masterwatt-550-watt-80-plus-bronze-semi-modular-mpx-5501-amaab-in.html
Sub-total: ₹57220
Total: ₹87534
Hello guys I'm from India ...I'm planning to buy a PC for occasional gaming and editing and on a budget . I have so far planned on getting...
Ryzen 5 2600
Asus prime b350 plus
GTX 1060 3gb
Corsair vengeance lpx 2400 2*8 =16gb
120gb kingston ssd and 2tb barracuda HDD
Corsair vs550 psu
With LG 24MP88hv monitor
Please help me out ...this is a one time investment for me
https://linustechtips.com/topic/944957-help-me-to-improve/
any site for us to look for parts?
The PSU is outright bad, only use those ranked tier 3 or higher.
Is that Kingston's A400 SSD?
Other parts like the mobo, graphics card can also be upgraded, but at least they arent critical problems.
Desktop benching:
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11509148
  • Faster RAM.
  • Try and get an x470 motherboard unless you know for certain the B350 has the updated BIOS, or you have a way to update it.
  • I'd try and get a better PSU, especially if you live in a place with dirty power.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11509173
Thanks alot ... yes it's Kingston a400
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11509853
4 hours ago, dizmo said:
  • Faster RAM.
The retailer told me its updated..
How about cx550
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11509864
amazon.in
mdcomputers.in
And what do you think of corsair carbide spec 4 cabinet
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11509916
How about cx550
If it's the modular one, it's not bad.
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11509975
I don't know why everyone from tomshardware and linustechtips are so wary of PSUs. And everyone says that the Corsair VS series are bad.
The ones that are bad are the cheap PSUs that usually say switching power supply of some sort and doesn't even have a 6-pin power connector. They can't supply even half of their rated power, but 90% of them lasts for more than 3 years. We call them "generic PSUs". They could catch fire though if overloaded.
I have a partnership on an internet cafe. 224 units are using Corsair VS450. Setup is:
Intel G2020
GTX 750 ti
4gb RAM
No hard disk - Units boot from Gigabit LAN
Corsair VS450 PSU
Systems have been running now for 5 years almost 24/7. The only times we shut down the PCs are when there's a natural calamity or when it's Christmas and New Year. Failure rate is very low. As of this writing, failed components have been:
2 Palit GTX 750 Ti - No video signal. I can't remember when these failed.
1 Corsair VS450 - Fan will spin then stop. CPU fan and case fans would spin too then stop. Didn't damage any of the components though. This specific unit started having this problem before a year. Should've had it replaced then but didn't bother because it rarely happened. Just had to do some plug and unplugging with the ATX cables and the problem gets fixed. It became a lot worse with the years that came so we had to replace the PSU. All components still worked great. Replacement of cheap PSU solved the problem.
In conclusion, in a span of 5 years with 224 units. Only 1 VS450 unit failed. And it's probably a defective one to begin with. It's assumed to not damage any components as well.
Please do note that I'm not pleaing for the acceptance of low quality PSUs. I'm just giving my thoughts on the VS series in which I think they're actually good. I bet there are a ton of other name brand PSUs that are regarded as bad, but would perform similarly to what is noticed with the VS450. I was thinking: EVGA 500B and some sorts.
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11510347
6 hours ago, Jajahhdjj said:
amazon.in
mdcomputers.in
I forgot to ask, what's the budget? I'd be talking trash if my recommendations exceed your budget :P
Spec-04 is fine
Desktop benching:
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11510682
@forregacc02 because our hardware cost a LOT more than what you've built, so we consider the cost of a PSU very cheap, pocket-change cheap. For a mid range build today, a CPU cost $175, a mobo costs $80, 16GB DDR4 cost $150, Graphics card cost $250, SSD costs $50, HDD costs $40, total of $745. How much does a PSU like the 500B cost? $25? a good PSU can costs twice as much, but that's still a tiny amount of money (7%) compared to the hardware it's powering. Not to mention we buy cases, case fans, keybaords, monitor, mouse etc. All that makes the proportion of expense on a PSU tiny, and we will spend that bit of money for assurance that our machines are safe.
Desktop benching:
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11510708
Ryzen 5 2600
GTX 1060 3gb
Corsair vs550 psu
GTX 1060 3GB is much better than a GTX 1050 Ti.
CX550 is fine, if the CX450 is available you might be able to save a bit. 450W is more than enough to power this build.
If you can squeeze in a 240GB+ ssd, that would be great.
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11510841
around 90,000INR
From Amazon:
From MDComputers
Sub-total: ₹57220
Total: ₹87534
Desktop benching:
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11511009
Thanks bro...
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11511053
Intel G2020
GTX 750 ti
4gb RAM
Corsair VS450 PSU
Thanks bro...
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11511059
4 hours ago, Jajahhdjj said:
around 90,000INR
90k is pretty good budget
My recommendation
GTX 1060 6GB- Rs 25000(1080p 60 fps on most AAA titles).......... https://www.nvidia.in/graphics-cards/geforce/pascal/gtx-1060/
Ryzen 5 2600x - Rs 18400 ...............https://mdcomputers.in/amd-hexa-core-ryzen-5-2600x.html?search=ryzen 2600x&description=true
Gigabyte ab350 gaming 3-Rs 8000 (solid b350 motherboard)................. https://mdcomputers.in/gigabyte-ga-ab350-gaming-3-rev-1-0.html?search=gigabyte ab350&description=true
DDR4 2400mhz sticks - Rs 6000 - 7500 but if you want to do editing better get 16gb for around Rs 13000 - 14000.................... https://mdcomputers.in/corsair-vengeance-lpx-8gb-ddr4-2400mhz-cmk8gx4m1a2400c16r.html
Also get DUAL CHANNEL  memory as ryzen is greatly benefited from that
Also better pickup  a CX 450 80+ bronze (white one) - Rs 3500................ https://mdcomputers.in/corsair-cx450-80-plus-bronze-cp-9020120-uk.html
HDD 1 TB- Rs 3000.......................... https://mdcomputers.in/seagate-1tb-barracuda-st1000dm010.html
LG 24MP88HV -Rs 15000 ................... https://www.amazon.in/LG-24MP88HV-24-inch-Monitor-White/dp/B01BGI6GZC
OR
lg 23mp68vq (75hz) - RS 10000 ................. ..https://www.amazon.in/LG-22MP68VQ-Full-Slim-Monitor/dp/B01IBM5V66/ref=sr_1_1?ie=UTF8&qid=1530949253&sr=8-1&keywords=lg+23mp68vq
Spec 04 -Rs 3000..............https://mdcomputers.in/corsair-mid-tower-spec-4-black-red-cc-9011107-ww.html
TOTAL - RS 89000 (If getting  16GB of RAM and LG 24MP88HV)
*These are online prices from
primeabgb.com
mdcomputers.in
amazon.in
nvdia offical site
ALSO offline prices are Lower than the online prices so it is better to get it from retail stores!
SSD is not a necessity,but  if you can get it great !
BTW are you from Mumbai?
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11511436
My recommendation
OR
primeabgb.com
mdcomputers.in
amazon.in
nvdia offical site
 Nope Mysore
Thanks bro ...I'll be editing and might play some games ..
https://linustechtips.com/topic/944957-help-me-to-improve/#findComment-11511547
