Hello, I've been having trouble deciding on what parts to get to build my computer. i know i want a GTX 1080 but I am having trouble picking all the other parts.I want to build a gaming pc that will last me a good while. I haven't built a pc since the late 90's so any help would be appreciated.
https://linustechtips.com/topic/944352-help-with-planning/
In addition to what @Lurick has said, what else do you want to do with the computer? Do you want to do YouTube or Twitch streaming? Any video encoding? Anything you will do on the PC must be taken into consideration...
Edited by TopHatProductions115
https://linustechtips.com/topic/944352-help-with-planning/#findComment-11503537
I as just wanting it for gamig but if i could i would love to make it to where i could get back into making games thats about all i';; use it for
https://linustechtips.com/topic/944352-help-with-planning/#findComment-11503561
6 minutes ago, Lurick said:
Budget? Country?
What FPS and resolution are you targeting?
Do you need a monitor? Keyboard? Mouse?
I don't really have a budget and i'm in the usa i would like the resolution to be 60 fps or more
i don't need a monitor or anything
https://linustechtips.com/topic/944352-help-with-planning/#findComment-11503569
Sounds good. Put together a couple quick builds that can be tweaked as needed but are a very good starting point.
For the AMD build the AIO isn't needed (same for the Intel build) but unlike the Intel build the AMD chip comes with a decent stock cooler so you could save money by dropping that. For the Intel build if you wanted to drop the cooler down, something like the Dark Rock Pro 3 or 4 would do nicely as well and would shave about $70 off the price.
AMD build:
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  ($209.99 @ Amazon)
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler  ($149.89 @ Newegg Marketplace)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($139.99 @ Walmart)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Amazon)
Storage: Crucial - MX500 250GB M.2-2280 Solid State Drive  ($69.85 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Amazon)
Video Card: EVGA - GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  ($514.98 @ Newegg)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($88.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $1458.66
Generated by PCPartPicker 2018-07-04 12:31 EDT-0400
Intel Build:
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($347.99 @ SuperBiiz)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  ($169.06 @ Amazon)
Total: $1625.73
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/944352-help-with-planning/#findComment-11503585
AMD build:
Total: $1458.66
Intel Build:
Total: $1625.73
Thank you for the help.
https://linustechtips.com/topic/944352-help-with-planning/#findComment-11503594
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($298.99 @ SuperBiiz)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.99 @ Amazon)
Motherboard: Asus - ROG Strix H370-F Gaming ATX LGA1151 Motherboard  ($132.64 @ Amazon)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($199.85 @ OutletPC)
Storage: Crucial - MX500 1TB 2.5" Solid State Drive  ($183.17 @ Amazon)
Video Card: Asus - GeForce GTX 1080 8GB ROG STRIX Video Card  ($609.89 @ OutletPC)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ SuperBiiz)
Total: $1618.51
Generated by PCPartPicker 2018-07-04 12:40 EDT-0400
https://linustechtips.com/topic/944352-help-with-planning/#findComment-11503617
