Hello! I am on a seriously tight budget, but I pretty much need a new PC. And I know pretty much nothing about computers.
-It must be able to do video and sound editing, hopefully some computer modeling.
-I would like it to be able to play a game like Skyrim, Legendary Edition, on Ultra graphics. And pretty much any other game I throw at it (On any graphics setting) for at least a few years now.
Overall, I want a computer that will last me well into the future with minimal upgrading or maintenance, even if I won't be able to do everything at it's best. I have about $700 on hand right now, and want the computer ASAP, but if I could get a considerable performance boost by spending even several hundred more, I'd rather go with that and wait.
Edit: At the same time, if I could get a PC that was just capable of editing and still able to play a few games for ~$300, that would be fantastic for a short-term solution!
https://linustechtips.com/topic/944157-help-me-build-a-computer/
1 minute ago, XivaKnight said:
Do you need a monitor mouse/keyboard/headphones?
I'd stick to medium/high settings, ultra tanks performance for basically no gain.
I have a mouse and keyboard, and headphones can wait. I do need a monitor, but that's good point about ultra. I'd rather get a cheap monitor to save on cost, and that wouldn't even be able to render higher-end graphics, would it?
I do have a TV, so monitor can always be a separate purchase well down the line
$700 gets you an R7 1700 and a GTX 1050ti right now, GPU pricing still kind of sucks otherwise.
Could also just spend like $400 on an R3 2200G PC and toss in a better GPU later.
PCPartPicker part list: https://pcpartpicker.com/list/X734NQ
Price breakdown by merchant: https://pcpartpicker.com/list/X734NQ/by_merchant/
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($209.99 @ Newegg Marketplace)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.49 @ SuperBiiz)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.90 @ OutletPC)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card  ($169.99 @ B&H)
Case: Cougar - MX330 ATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: EVGA - 600B 600W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
Total: $713.34
Generated by PCPartPicker 2018-07-03 21:55 EDT-0400
Total: $713.34
for $100 more newegg has a rx 580 for $259 after rebate
https://www.newegg.com/Product/Product.aspx?Item=N82E16814137290&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
17 minutes ago, Beowulff83 said:
Better off with the golden sample RX 580 at $269
But that means getting an R3 2200G for now instead of a cheap R7
https://pcpartpicker.com/product/vt2rxr/powercolor-radeon-rx-580-8gb-red-devil-golden-sample-video-card-axrx-580-8gbd5-3dhgoc
Of which the R3 2200G will be fine for gaming at 60hz
which programs will you be using?
Thank you so much for these lists, especially so fast.
Two follow-up questions: When the GPU prices finally do drop, what sort of price range do you think we'd be looking at, in about how long?
And, this is a bit of a change of direction, but would I be able to accomplish basic video editing (And still, maybe some gaming) with a much cheaper computer? Something closer to $300? I'm still just a novice, I probably won't be getting into any heavy projects anytime soon while I hone my skills. My software is Vegas Pro 14 and MAGIX music maker. I don't need it done fast, just as long as it can do it (Though I am desperate to start gaming again :P)
Motherboard: ASRock - X370 Pro4 ATX AM4 Motherboard  ($59.99 @ Newegg)
Storage: Inland - 240GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Case: Cougar - MX310 ATX Mid Tower Case  ($33.98 @ Newegg)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($41.88 @ OutletPC)
Total: $710.81
Generated by PCPartPicker 2018-07-03 23:42 EDT-0400
2 hours ago, XivaKnight said:
An R5 2400G will be fine if you're just doing 1080p editing.
Probably still want 16GBs of RAM for that though.
PCPartPicker part list: https://pcpartpicker.com/list/dTYdFt
Price breakdown by merchant: https://pcpartpicker.com/list/dTYdFt/by_merchant/
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor  ($156.00 @ Amazon)
Total: $489.36
Generated by PCPartPicker 2018-07-04 01:10 EDT-0400
Total: $489.36
Thanks! Would I be getting much gaming capability out of this?
720p high, 1080p low/medium pretty much. My choice would be this, since it will give you a great base to upgrade later and will do 1080p high no problem. That monitor is a steal btw for a 1080p IPS.
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($94.99 @ SuperBiiz)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($55.98 @ Newegg)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.39 @ OutletPC)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB OC Edition Video Card  ($174.99 @ Amazon)
Case: Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case  ($39.64 @ Amazon)
Power Supply: SeaSonic - FOCUS Gold 450W 80+ Gold Certified Semi-Modular ATX Power Supply  ($53.99 @ SuperBiiz)
Monitor: AOC - I2279VWHE 21.5" 1920x1080 60Hz Monitor  ($79.99 @ Best Buy)
Total: $692.96
Generated by PCPartPicker 2018-07-04 05:16 EDT-0400
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
No it's like half the speed of an RX 560, and a good deal slower than an RX 580, but it does leave you extra cash for an RX 580 upgrade in the near future
If you just buy that R7 1700 system you can easily upgrade the GPU when the next generation drops in months, a 1050ti will be fine for 1080p gaming.
11 hours ago, NelizMastr said:
That case has no airflow, go for the Q300L if Micro ATX
