I have steam installed on my ssd because whenever I had it on my hdd it would crash and nothing would work, but now whenever I try to install games onto my hdd it still crashes and I have no idea why.  I also get transfer problems when I try to put files in general on my hdd anybody have any idea what might be wrong?
https://linustechtips.com/topic/94402-storage-drive-issues/
I think you might have a bad harddrive. I am trying to think of what programs I use to test harddrives and am drawing a blank. Sorry. Hopefully someone else chimes in, or when I remember I will post it.
EDIT: http://www.hdtune.com/
It can do a hhd data check, as well as tell your SMART errors and other issues that might be present.
https://linustechtips.com/topic/94402-storage-drive-issues/#findComment-1266020
I don't think I have a bad drive because it was working fine before I installed my ssd but thanks for your response anyway
https://linustechtips.com/topic/94402-storage-drive-issues/#findComment-1266027
Hmm. Well, unless the wire got slightly knocked out, I am not sure what could be the issue. Check the wires, and just for the heck of it run HDTune anyways? I have never seen an issue like that besides it being a bad drive personally.
https://linustechtips.com/topic/94402-storage-drive-issues/#findComment-1266030
The problems started when the SSD was installed?
Ya the problems started when the ssd was installed
Do you share the SATA power connector (like from same cable) between SSD and HDD ? I suspect unstable power to your HDD
Ya I do I've just always done that between the cd drive and the hdd so I assumed that the power cable wasn't the issue
https://linustechtips.com/topic/94402-storage-drive-issues/#findComment-1266091
try replacing your HDD's Sata cable and checking the power cable to the HDD is ok.
Try running a HDD test on you HDD. I find the western digital life guard software is pretty good for testing HDD's (not SSD's). use the extened test.
If the HDD tests ok then it could be a corrupt partition table or file system, in which case you might want to run a full check disk on your hdd too.
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/94402-storage-drive-issues/#findComment-1266903
