I have a new ASUS GTX 1060 DUAL 3GB card. I use a dvi cable from my monitor to connect it, but when I connect it to my graphics card, the quality looks horrible. To add on to that, I cannot get passed the Windows 10 logo on startup, my computer just goes black screen after the little windows logo. However, when I plug it into my motherboard, it's completely fine. What should I do?
https://linustechtips.com/topic/943934-help/
5 minutes ago, Ashiok said:
Yes, but I don't have a cable. I could easily get one though, should I?
Yes, yes of course.
DP>HDMI>DVI>VGA
Please quote me or @ me in your response so I get a notification.        I really really really really like small text.
Occupation: Gamer | Hours: 24/7 Full-Time | Hourly Pay: 0 | Benefits: Chick Magnet
FINISHED BUILD - VIEW PROFILE
If you say I'm not always right, but I am, I will say I am right.
rekt
https://linustechtips.com/topic/943934-help/#findComment-11499811
2 minutes ago, Ashiok said:
Oh, didnt know that. I'll pick one up today. Thank you!
Have a good day :)
rekt
https://linustechtips.com/topic/943934-help/#findComment-11499824
Okay, so I got an HDMI cable and it is working while plugged into my graphics card. However, my monitor must have DVI to work so I am currently using both. Also, my DVI doesn't work for some reason in the graphics card, my screen just goes black after windows loads in so I have it in my motherboard. Is this draining performance or is it fine?
https://linustechtips.com/topic/943934-help/#findComment-11500114
Wait... where is the HDMI going?
rekt
https://linustechtips.com/topic/943934-help/#findComment-11500486
