UPS Woes
Solved by Razor Blade,
7 minutes ago, Donut417 said:Unplugged it and the UPS shut off with out a sound. Did the test twice to be sure. It turns off. So you thinking I should just say fuck it and buy new batteries? Because that would be the best solution. Now I just gotta figure out the best place to get them.
I was looking for batteries a while ago for my UPS. Digikey would be a good source if you want something like Panasonic or Yuasa batteries. If you don't really care, you could go with good old Amazon. The last place I would go would be that batteries+bulbs place...you'll likely way overpay for any batteries you get there.
