Hello. 3 years ago I bought a Lenovo thinkcentre m73 mini tower pre-built pc. I've been upgrading it since, but now I'm wanting a new cpu, which would need a new case, motherboard, and ram. That would, however, require hundreds while I only have $200. What I'm asking is can I still get anything significant for the system? I still have all the original parts for it, but I'm hoping to get something for the cpu. What would an Intel i5 4570 be worth today? Or maybe the whole system? Thanks in advance!
https://linustechtips.com/topic/943559-selling-dated-parts/
i5 4570 are worth like 70$
why not just buy an i7 it should be plenty upto a 1080
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/943559-selling-dated-parts/#findComment-11496194
3 years pc is still good.
why not spend for a new gpu, ssd or add more memory.
you won't get drastically better performance by getting new cpu.
From what i see in the specifications it has poor gpu.
with $200 you can get a gtx1050ti that will boost your gaming to the next level.
https://linustechtips.com/topic/943559-selling-dated-parts/#findComment-11496238
8400 + new mobo + ddr4 will cost more than 400.
its better to buy used 4th gen i7.
https://linustechtips.com/topic/943559-selling-dated-parts/#findComment-11496330
I feel like you guys are missing the point a bit, I wanted to know how much I can get for the computer without the graphics card. I have worked out the final pricing of the upgrade already and I'm hoping to fill the gap between my budget and the cost with this computer.
https://linustechtips.com/topic/943559-selling-dated-parts/#findComment-11496358
