So I have 2 windows 10 pc and one 2008 Mac Pro. I have my laptop connected to the Mac Pro via Ethernet so I can use the Mac as a server and the Mac has two Ethernet ports but when I connect the sff desktop (dell optiplex 960) it won’t find the Mac at all on the network tab but it works fine on my laptop
https://linustechtips.com/topic/943358-help/
9 hours ago, Kingdomkey said:
No how do I do that
There are a couple things going on if they are connected directly that could be a problem.
1. Your NIC (the hardware card) needs to be able to support crossover. Some do, some don't. If they don't your option is use a crossover cable or a switch.
2. You'll have to assign an IP somehow. Systems will auto generate an IP sometimes and this might work but it's better to affix one to them in the network settings.
"Only proprietary software vendors want proprietary software." - Dexter's Law
https://linustechtips.com/topic/943358-help/#findComment-11495589
