Painting PC case need help
Go to solution Solved by NoRomanBatmansAllowed,
Normal spray paint should be fine.
Use at least 2 coats, but add more if you feel like it.
I have a Rosewill tyrfing, and I was wondering if it's a good idea to paint the inside of my case. It's black on the inside and outside I want it white. Should I use high temp spray? How many coats on inside and outside?
Main pc
CPU: AMD RYZEN 2200G || GPU: EVGA GTX 780 || PSU: EVGA 500W  ||  MOBO: MSI B350M MORTAR ||
RAM: BALLISTIX SPORT LT 12GB (4X3) DDR4 3133 MHz ||  CPU COOLER: AMD WRAITH STEALTH || SSD: SILICON POWER S55 120GB (BOOT) ||
HDD: WESTERN DIGITAL 500GB BLUE 7.2K RPM, 200GB random Toshiba HDD || CASE: Thermaltake View 28 ||
Consoles
|| XBOX 360 || NINTENDO WII U || PLAYSTATION 3 || PSVita (1000 model, henkaku fw 3.87 || NINTENDO 3DS XL || Nintendo Switch Lite ||
https://linustechtips.com/topic/943310-painting-pc-case-need-help/
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
Just a can or two should cover the whole thing?
Main pc
Consoles
I used plasti dip on my PC, ive been doing it for about 2 years, When ever you are tried of the color it is easily changeable (When you try to remove it)
Ive changed the color of my case 3ish times, I think it is a much better option the spray paint...
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
Your going to need to properly prep the surfaces by scuffing it with scotch brite or fine sandpaper before ideally applying a light primer. FOr the inside your going to get a fair bit of over spray unless you take apart the whole case by removing the rivets. As for the amount of paint and coverage it depends on the paint and color but usually around 3 can should be able to take care of it.
If you want more in depth details I have a guide that goes over this under Case Painting.
i'll look into this. thanks!
Main pc
Consoles
