5 minutes ago, Srbin said:
how do i know if i know if mothetboard supports overclocking
im want to build new pc with ryzen cpu and im on budget so i need help
Look up the model of the mobo. It'll state if it does or not.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/943243-need-help/#findComment-11493407
If it's a B350, X370 or X470 motherboard it supports overclocking. All Ryzen series CPU's on the desktop support overclocking.
Of course how much you can OC is dependent on the quality of your board, cooler and of course luck with getting a good binned CPU.
Reminder: you might want to use something that is not the stock cooler with more extensive overclocking and with Ryzen 2xxx CPU's you need to run a BIOS update on most B350 or X370 boards.
https://linustechtips.com/topic/943243-need-help/#findComment-11493408
