Hey,
has anyone had that issue, where when you type something, and you mess up, So you go to move your courser over it, and it like Highlights one letter, and when you start typing it erases the next letter?
How the heck do you stop this from happining, or is it built in? It dosnt happen 100% of the time.
The video shows what im talking about..
Texting issue.webm
Virus check on the file, if anyone is worried.
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/942961-weird-backspace-issue/
I couldn't download the .webm, sorry.
Is it a general issue or is it only in a specific application?
Because it sounds like you've just accidentally pressed the insert (ins) key on your keyboard.
If that is the case, then you just have to repress the key to fix the issue.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/942961-weird-backspace-issue/#findComment-11491125
