USB Type C cable specs?
Go to solution Solved by it_dont_work,
It'll depend on how many pairs are in the cable, I bought a couple which where 'high speed usb' for charging cables to throw in the car, they all ended up being normal usb2.0 cables. Yay for cheap ebay crap not.
certified 'high speed' is usually usb2.0
certified' superspeed' is usually usb3.0
after that I don't know, never had anything faster than 3.0
EDIT: here's a pic from kingston
I bought a ToughTested heavy duty coiled USB a to USB type c from Microcenter.
The package doesn't say what usb interface it uses, nor does the actual product website. Is there a way for me to find out which USB interface it uses?
Wii-U Wii-U Wii-U Wii-U Wii-U Wii-U Wii-U *insert firetruck picture* :)
https://linustechtips.com/topic/942733-usb-type-c-cable-specs/
whatever the port supports
if a port supports the 1.1 spec it'll only transfer at 1.1 speed, the cable is just a conductor between point A and point B
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/942733-usb-type-c-cable-specs/#findComment-11489144
So if I have a port that does Thunderbolt 3, would it be able to support that? Or 10 GBps USB 3?
https://linustechtips.com/topic/942733-usb-type-c-cable-specs/#findComment-11489184
I don't think that it will support Thunderbolt 3, otherwise it will have that advertising plastered all over it. I think it may be a USB 2.0 USB-C cable, maybe supporting USB 3.0 at best. For example: Apple sells a USB-C cable that also comes with their MacBook Pros, it is designed for charging and because of this it does not have Thunderbolt support or even USB 3.0 support, they sacrificed data speed for charging capacity. It also doesn't seem like this cable supports USB-PD even, as it says maximum power is 15W which I believe is way lower than what USB-PD does.
I may be wrong about this though, USB-C, USB-PD and Thunderbolt is extremely confusing and the standards don't seem very well implemented or very clear to understand.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/942733-usb-type-c-cable-specs/#findComment-11489247
High speed means at least 2.0. That's the best I'd hope for.
USB-A 1.1-2.0 has 4 contacts/wires. 3.0 and 3.1G2 has 9.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/942733-usb-type-c-cable-specs/#findComment-11489382
1 hour ago, KhandakeF said:
i'm sorry but if it's just an empty box, it's not going to support any data transfer xD
Insanity is not the absence of sanity, but the willingness to ignore it for a purpose. Chaos is the result of this choice. I relish in both.
https://linustechtips.com/topic/942733-usb-type-c-cable-specs/#findComment-11489394
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/942733-usb-type-c-cable-specs/#findComment-11489435
3.1 Gen 2 is SuperSpeed+
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
https://linustechtips.com/topic/942733-usb-type-c-cable-specs/#findComment-11489441
